-   -   Safe longterm temps? (http://www.hardwarecanucks.com/forum/cpus-motherboards/37071-safe-longterm-temps.html)
ToXic October 13, 2010 05:01 PM
So im currently clock testing my 920, and im at 4021.67 or ~4 Ghz, and im wondering if 38 idle and load at about 75 will be safe for the long run?
Pushing about 1.23v, thats the lowest i can go without BSODs.
_dangtx_ October 13, 2010 05:08 PM
i would have to say yes. its hard to kill cpus, if you dont push mad voltages thru them.
martin_metal_88 October 13, 2010 05:26 PM
Totally safe...if these temp are under stress test, then Extreme use like gaming will be like 5 degree under usually.
xinhang October 17, 2010 06:04 PM
75 under 100% load is very acceptable temperature
Jake_HT October 17, 2010 06:19 PM
what they said*
*the creation of this post was totally justified
lowfat October 17, 2010 07:30 PM
Keep it under 95C and you'll be good. :biggrin:
You'll likely reach instability before you'll need to worry about temperatures.
