Old October 7, 2010, 03:35 PM
Arinoth's Avatar
Originally Posted by botat29 View Post
OC ? , why everything have to be OC..... from what I read the cooler need for OCing will block the pci-e.
This is true, you can't really practically overclock the cpu and use a gpu card at the same time as there will be almost no heat sinks that wont block a pci-e lane that close. The only thing i can think of is watercool and well thats not air cooled.
Here I am: here I remain
Old October 7, 2010, 03:58 PM
martin_metal_88's Avatar
First of all, because OC is damn fun and give you a performance boost where you need when your CPU is getting age.
H50 H70 would work just perfect with that :) Or, just mount like a 212+ on the other direction and it will work...Heatskink problem fixed yay:D
Old October 7, 2010, 04:05 PM
botat29's Avatar
Don’t get me wrong…. I like the ocing of Windwithme , it’s show that he try and push this board, it give me confidence , and it’s why I order one. Now someone know if those Intel new GPU-CPU are good for HTPC, after all it’s what I intend to do with this board.
Old December 11, 2010, 10:04 AM
Originally Posted by martin_metal_88 View Post
Sweet power from a mini monster! Curious how long the board could keep a 4Ghz and over OC.
How about 6 minutes, 18 seconds and 469 milliseconds.
ITX Overclocking Contest: H55N-USB3
Of course, the dry ice won't fit in your case too well.
Intel Core i5-655K & Core i7-875K Unlocked Processors Review Comment Thread SKYMTL CPU's and Motherboards 23 May 29, 2010 05:20 PM
Intelís Latest 32nm Clarkdale Platform - Core i5 661 With BIOSTAR H55 OC 5G On Air windwithme Member Reviews 6 January 15, 2010 08:21 AM
