Old September 26, 2010, 11:58 AM
Default ASUS M4A89 GTD PRO and RAM
Noob question here. Looking to purchase this motherboard for new build. Last build was 4 years ago when DDR3 wasn't really an option. Since then I see that DDR 3 is available but what surprised me the most is that rather than running the memory in pairs you can now put 3 sticks of memory in rather than 2 or 4.
Can this board use 3 STICKS of memory rather than 2 or 4 and what does this change. Does the motherboard run in dual channel when there are 3 sticks of memory or does it revert to single channel.
Thanks everyone for your replies.
André
Old September 26, 2010, 12:07 PM
punk_zappa's Avatar
The 3 is for triple channel i7. Your board will only support dual.
Old September 26, 2010, 12:30 PM
Thank you very much, has made my memory choices that much easier.
Old September 26, 2010, 01:27 PM
fishingfanatic's Avatar
Smile CPUs and Motherboards
Yeah, triple channel where yours is dual channel. Depending on the OS you're using, you use 32 bit or 64 bit. With 32 bit, your OS sees 3gbs, but most kits come in 2 or 4 gbs. The extra 1gb doesn't hurt.With 64 bit you can use up to 8gbs of ram, which is what I used on my old system and it was really quick.
Any of the lifetime warranty ram is good. I prefer Mushkin, with G Skills, Patriot and Corsair being 3 other makes with lifetime warranty as well.
Good luck with your new system and enjoy the new comp.
Welcome to HWC btw!
Old September 26, 2010, 05:21 PM
RBA RBA is offline
See my sig for the ram I'm running. No issues here but I don't OC.
Old September 27, 2010, 03:56 PM
Thanks again for all your help, will keep you all posted on the new Compute, am doing the shopping and comparing in the next two weeks.
Old September 27, 2010, 04:11 PM
sswilson's Avatar
Don't ignore the 3 channel sets for price though... if you find a really good sale on a three channel set you'll just have one for a spare. :)
How much ram for XP Pro 32 bit? GMJim RAM 7 February 27, 2010 08:49 PM
[FS] E8400 E0, P5QL-Pro, DDR2 Kingston 4 gb Ram flightsimnerd Buy/Sell & Trade 28 February 8, 2010 06:29 PM
RAM for Macbook Pro Skootles RAM 5 December 2, 2008 08:15 PM
Asus p5wdg2 ws pro help maurier CPU's and Motherboards 0 June 23, 2008 08:24 PM
FS-s939 X2-3800, OCZ ram, Ac Freezer 64 Pro, ASRock mobo, DFI mobo, Asus mobo..more stoanee Buy/Sell & Trade 14 June 7, 2008 06:24 PM
