Old September 16, 2010, 12:09 PM
rjbarker's Avatar
Default CPU Grease
Hey guys...sorry..having a "Bob Zone" morning....
Remember about ...what...year and a bit ago a bunch of us Members recieved a new Tube of thermal paste to try out?
What was the name of it again ....I remember the word "Diamond" I think.....I used a pea size dab in the middle of my 920....and had to let it sit in some hot water for awhile to loosen it up a bit. the tube prior to installation)
Would my tube of this stuff still be alright? I remember I had good temp results with it right off the bat..
Just curious as I'm going to be installing my 980X soon and wondering if I would be better of getting some MX3....or stick to this other stuff I have (name?)
Thanks Members ;)
Firestrike Extreme: 23.772K
https://www.3dmark.com/fs/17562471
Timespy: 18.613K
MARK 11: 40.185K
https://www.3dmark.com/3dm11/13079691
Old September 16, 2010, 12:14 PM
should be fine if you kept it nice and sealed up!
Old September 16, 2010, 12:15 PM
Jake_HT's Avatar
IC Diamond (innovation cooling)
IC7, or IC24 depending on size of tube.. It's good stuff, and yes, it'll be fine
Innovation Cooling
http://jakeht.deviantart.com/
Old September 16, 2010, 12:27 PM
2 yrs ago :) at least.
http://valid.canardpc.com/show_oc.php?id=932179
"Be so good at what you do that you cant be ignored"
Old September 16, 2010, 12:30 PM
gingerbee's Avatar
yup it's been about 2 years
Old September 16, 2010, 12:42 PM
rjbarker's Avatar
^^^^ Thanks Ginger n Jason.....shivt your "aging" me......2 yrs eh?!...so thats at least how long I've had my 920 in thier...uggghhh....I feel "old" ;) Gonna go and "dig-up" that tube......
...thats right IC7 Diamond....
Timespy: 18.613K
MARK 11: 40.185K
Old September 16, 2010, 01:10 PM
look at it, if it starts powdering,leaking or anything in between, off to the recyclers.
Old September 16, 2010, 01:22 PM
exactly ,, mine seem to have separated like dan says.. dry but with wet areas, so i tossed it..spread like dried up peanut butter..
Old September 17, 2010, 02:54 PM
I liked it so much, I bought another tube.
Old September 17, 2010, 03:52 PM
Eldonko's Avatar
Hardware Canucks Reviewer
I still use good ol AS5. I go thru so much thermal paste that I find that diamond stuff to be waaay overpriced. Plus you have to use 3x as much of it.
[Review] 2010 CPU Blocks RoundUp - Supreme HF, Apogee XT, Koolance CPU-360 and HK 3.0 Dazmode Water Cooling 3 May 29, 2010 06:52 PM
Can I add a cpu with slightly diff speed rating to existing single CPU config? HoTiCE_ CPU's and Motherboards 3 April 1, 2010 08:52 PM
Zalman CNPS 9900 and ZM-STG1 grease not giving a good temperature drop. C_O_N Air Cooling 10 July 22, 2009 02:12 AM
Thermal Grease n Lapping rjbarker CPU's and Motherboards 1 March 20, 2009 07:13 PM
Zaward Super Thermal Grease review Babrbarossa Reviews & Articles from the Web 0 May 11, 2007 07:59 AM
