Old September 9, 2010, 01:45 PM
Default phenom II 555 problems
so i built this pc last night and noticed the cpu won't underclock when the pc is idle.I have cool and quite enabled in bios,any ideas of whats wrong?
Old September 9, 2010, 02:41 PM
try loading bios defaults just in case? also, do you have anything software that might be able to touch on that subject too?
that or its disabled/buggered when you push it 1mhz over stock. is this on the ga-890 ?
Old September 9, 2010, 03:25 PM
francisw19's Avatar
Have you set the power options in the Winodw's Control Panel to 'Balanced' or 'Power Saver'? C'n'Q won't work otherwise.
Old September 9, 2010, 03:31 PM
for some reason windows was auto set to max power,thanks
Old September 9, 2010, 03:37 PM
francisw19's Avatar
Nice to hear it's working now!
Old September 9, 2010, 04:19 PM
Bond007's Avatar
I had the exact same problem for the first day on my comp. Glad to hear it was the same easy fix.
Old September 18, 2010, 08:47 AM
Just a quick thought, did you try unlocking that processor or playing with the multiplier/clocks?
[FS] Main PC (5770 CF, X2 555, etc) poroporo Buy/Sell & Trade 3 May 30, 2010 11:54 AM
Temperatures on an x2 555 poroporo Overclocking, Tweaking and Benchmarking 3 May 14, 2010 07:27 PM
Phenom II 555 puroman1 CPU's and Motherboards 1 February 3, 2010 05:04 PM
AMD has problems with Phenom X4s and 780G Hardware Canucks Reviews & Articles from the Web 30 March 22, 2009 03:20 PM
