Old December 19, 2007, 02:05 PM
donimo's Avatar
OK, I changed the order, ncix guys prolly flagged me as annoying as s**t but hey...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old December 20, 2007, 07:19 PM
slugbug's Avatar
Building a new computer for my nephews friend and the Gigabyte looks like it'll fit the bill.
Ordered 2 of them.
Old December 21, 2007, 03:15 PM
reaverclan's Avatar
Originally Posted by werty316 View Post
Agreed, if you don't care for SLI, and no sane person would, the P35 chipset is just a better choice when compared to the Series 6 chipset.
Abit's IP35 Pro is growing on me but I doubt I'll get one.
what about the x38 chipset is that ok for ocing
Old December 21, 2007, 03:47 PM
werty316's Avatar
I think of the x38 as a "plus" version of the P35 since the x38 has subtle differences when compared to the P35 like the amount of PCIe lanes, PCIe 2.0, etc. Along with other little details the x38 is just as potent as the P35 when it comes to overclocking.
General x38 motherboards are for those with deep pockets since they are quite expensive boards.
Here is a comparison chart between the x38 and P35: Intel® Product Comparison Chart
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old December 21, 2007, 04:29 PM
reaverclan's Avatar
k is it worth it if i got he money which i do, cause p35 does say 2.0 and 8800gt is a 2.0 which is why it wont work on my asrock lol but i really want to dump the asrock anyway lol. if i get x38 have u used any of them? recommend any? i have my choices on my thread oint he mobo section i decided im not goan put he money out for sli anyway lol
Vista SP1 RC Opinions? Supergrover O/S's, Drivers & General Software 4 March 8, 2008 05:29 AM
Opinions on Gigabyte 3D Aurora 570 Scart Cases 4 March 6, 2008 02:23 PM
Anyone using an X-FI Elite Pro-opinions Ukonjack Audio 1 November 28, 2007 07:02 PM
First OC attempt,any suggestions or opinions? Mibs Overclocking, Tweaking and Benchmarking 9 August 12, 2007 08:59 AM
opinions on this mobo Jim CPU's and Motherboards 6 July 26, 2007 08:23 PM
