Old December 4, 2007, 09:25 PM
reaverclan's Avatar
Exclamation help!!!!!!!! which mobo for sli but only one card atm?
hi, which of these is best for sli but for in future. im not going to sli now. and 8800 gt xfx is going in it. plus whats in my sig thanks for your time.
Newegg.com - MSI P6N SLI Platinum LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
Newegg.com - ASUS P5N-E SLI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
Newegg.com - ASUS P5N32-E SLI Plus LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
Newegg.com - GIGABYTE GA-N650SLI-DS4L LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
thanks again
cheers,
rvc
The-Jew/Xfire=reaverclan/My Photobucket
mobo:GA-P35-DS3L Rev.2(BIOS F7)
os:
Win7 Pro x64/Ubuntu 9.10 x64
cpu:Q6600@3040.0GHz
cooling:
OCZ Vendetta 2 ram:4GB(4x1GB) Corsair XMS2 800 4-4-4-12
gpu:EVGA GTX280 SSC hdd:Seagate 1024GB psu:HX620w
disp:
Vizio 1080p TV (32'') sound:X-Fi Xtreme Gamer case:Antec 1200
Old December 4, 2007, 11:16 PM
I've always been a big fan of Asus' motherboards, so I'd suggest you get one of those two. And why not make it the high-end one and go with the P5N32-E?
Old December 5, 2007, 07:49 AM
Out of those... P5N32-E SLI
Old December 5, 2007, 08:45 AM
Jack Rabbit's Avatar
ditto the P5N-E SLI but you should really try for the P5N32-E; the newer one with the 680i chipset. If you are looking for a board to keep as long as you can you should not start with one that is already behind the curve.
Old December 5, 2007, 09:07 AM
reaverclan's Avatar
k thanks i thought same thing but just double checking, if i can afford the 32 ill get it if not ill get the E
os:
cpu:Q6600@3040.0GHz
cooling:
disp:
Old December 5, 2007, 09:26 AM
P5E is not true 680i its two chipsets to make one hybrid.
Old December 5, 2007, 09:58 AM
reaverclan's Avatar
i know im getting the 650i version the 680i would bust my bank anyway i only got 180 to spend on it
os:
cpu:Q6600@3040.0GHz
cooling:
disp:
Old December 5, 2007, 10:15 AM
I do not know why Asus has to be so confusing about ther numbering scheme.
Asus P5N32-E SLI Plus - hybrid
NVIDIA® Dual X16 SLI
(C55+MCP55P; a.k.a. nForce®650i SLI & nForce®570 SLI)
ASUS HybridUp Technology
* Support SLI-Ready Memory Technology
Asus P5N-E SLI - 650i board
NVIDIA nForce® 650i SLITM
Asus P5N32-E SLI - 680i board - it is exactly the same board as the top-o-the-line Striker Extreme just without some of the fancy lights and such.
NVIDIA nForce® 680i SLI™
I was just reading some reviews that said the 650i is almost as good as the 680i. The big difference is the added bells and whistles in the newer chipset.
Old December 5, 2007, 10:16 AM
ebdoradz's Avatar
be aware that certain board with 680i chipset wont completly support the new generation of C2d/c2q even if the chipset fully support them
nvidia made a annonce on this, if im right techpowerup have already talk about this but i cannot find the link right now.
i would double check to see if the 650i have the same trouble be4 buying a card with a nvidia chipset
EDIT found the link here :
bit-tech.net | Nvidia 680i boards don't support Penryn?
Gigabyte GA-MA790XT-UD4P / AMD Phenom II x3 720BE @ x4/ Crucial Ballistic DDR3 / Sapphire 4830 5112mb / Corsair 620W PSU / 2*80GB Seagate
DFI LP nF4 Ultra-D / AMD Opteron 165 @ 2.7Ghz/ 2*1GB OCZ Gold GX XTC / Sapphire X1950XT / Fortron 450W PSU / 2*Maxtor 80Gb
ABIT KT7A-RAID / AMD Athlon XP 1800+ @ stock/ 2*256mb PC133/ Geforce 4 mx440 / 250W PSU / Maxtor 20GB
Old December 5, 2007, 10:21 AM
reaverclan's Avatar
no big im getting this one and i never have the latest cpu's and such anyways
im only upgrading board so i get full potential out of my 8800gt and cause my asrock board kkeps my stock stuff at cruddy voltages ect.
os:
cpu:Q6600@3040.0GHz
cooling:
disp:
Which mobo should I buy? yycraven CPU's and Motherboards 27 January 15, 2008 07:31 PM
Mobo and DVD DSNB Troubleshooting 6 December 27, 2007 06:08 PM
Bad cpu/mobo for o/c? Frustian Troubleshooting 6 November 3, 2007 10:09 PM
mobo, which one to buy ? Jim CPU's and Motherboards 20 August 27, 2007 03:35 PM
Mobo cdn_Madrach HTPC Systems & Software 8 July 6, 2007 05:51 AM
