Old December 4, 2007, 10:21 PM
BALISTX's Avatar
Default Help design new rig.
I need help designing a new rig. As some may know I sold the rig that is in my sig. The only thing I have left is the 250GB Seagate SATA hard drive and the LG DVD-+RW SATA drive.
My budget is $850.00
This will be used for gaming.
It can be either Intel or AMD.
:help:
Heatware
HWBOT
Old December 5, 2007, 06:01 AM
3.0charlie's Avatar
Not easy... but feasible.
GA-P35-DS3L 104$
Vista Home Premium 99$
E6750 227$
Galaxy 8800GT 269$ <---- in stock!!!!
OCZ Platinum XTC Rev.2 PC2-6400 86$
Antec Sonata III w/500W PSU 111$
Total: 899$ @ NCIX, with no specials.
edit... forgot a hsf. AC7 Pro could do the trick: 26$
Hydro-Quebec is salivating...
Old December 5, 2007, 11:32 AM
BALISTX's Avatar
Also it needs to include a case and PSU
Heatware
HWBOT
Old December 5, 2007, 11:33 AM
3.0charlie's Avatar
yup, the Sonata (with the PSU) is there, last item.
Old December 5, 2007, 03:03 PM
Mr. Cipher's Avatar
you can price match some of that stuff with tddirect to save a few $$: $50 on CPU, $10 on MoBo, $12 on case/psu, $12 on ram, xfx 8800gt xt/xfx 8800gt same price, galaxy oc 8800gt for $12 less = savings of $84-$94.
Expands your budget a little bit!
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
Old December 5, 2007, 03:44 PM
Droc's Avatar
with the money saved, Id stretch for the Q6600
Old December 6, 2007, 12:35 PM
Don't get the OCZ's they have crappy IC's on the 6400's. They don't start using micron IC's until you get to at least pc2-7200
You can probably get crucial 6400's for the same price but they'll b micron IC's for sure.
As for the vid card I would suggest maybe going for the ATI 3850 instead of the 8800gt.
Sure its not as fast but its about $100 cheaper and you can always get another one later to get 8800GTX speeds.
With the money saved from the 3850 you can easily afford a q6600.
Old December 6, 2007, 01:40 PM
3.0charlie's Avatar
Guys, give me break about my choice of components! I did this in less than 5 minutes with a coffee on hand, only to show that is was possible, within the budget.... if better, cheaper components are available, it's even better that way!
John
Old December 6, 2007, 02:00 PM
"Quote This..."
what's with the vista home premium?
OS shouldn't be a part of the quote, let alone that.
Old December 6, 2007, 02:32 PM
Misoprostol
Guest
Posts: n/a
I'd drop the CPU down as low as you can go to save money and put it all towards VGA. That board is a great overclocker.
Antec 900 Paint and Design Suggestions JuggsJr Cases 10 January 10, 2008 01:53 AM
AMD offer 1/4 mill prize for architectural design competition Babrbarossa Off Topic 1 March 12, 2007 01:33 PM
Intel Tests Chip Design With 80-Core Processor Supergrover Press Releases & Tech News 0 February 16, 2007 01:19 PM
