Old December 6, 2007, 02:54 PM
MpG's Avatar
MpG MpG is offline
Originally Posted by Misoprostol View Post
I'd drop the CPU down as low as you can go to save money and put it all towards VGA. That board is a great overclocker.
Within reason, anyway. The new generation of processors are coming with some really lousy multipliers, and he doesn't want to have to spend all that saved money on higher-clocking RAM.
Old December 6, 2007, 11:08 PM
BALISTX's Avatar
It appears my budget got cut down by the wife cause I apparently forgot we have to buy Christmas presents for family. Budget is now $700 including tax and shipping.
I decided I'll go the SFF route and to cut down on costs going AMD by getting the Athlon64 X2 6000+ 3.0GHz.
I'm stuck on deciding on a few motherboards and I have been researching but all of the stuff I've been reading is just merging together in my head. Ugh Information overload.
The motherboards are down to these. Prices are from NCIX.
ASUS M2A-VM - $72.06 (God that PCB is fugly)
Biostar TF7025-M2 GF7025 - $77.35
Biostar TForce TA690GAM2 - $77.49
Gigabyte GA-MA69GM-S2H - $86.87
Heatware
HWBOT
Old December 7, 2007, 10:27 AM
omgwtf's Avatar
I'd go with Gigabyte but..it supports only 1.8V DDR2 DIMMs...that's tricky, you gotta be careful. When I bought my sistem I had some little problems with the M2N-E and the Ocz ram's..if you do a search on the net you'll find that on most m2n-e mobo's they will fail..but heh the luck..
Memento mori
Old December 8, 2007, 11:24 AM
"Quote This..."
Here is a review of the MSI budget mobo. this would be my choice for sure.
AnandTech: MSI P35 Neo2-FR: Platinum performance for under $100
Old December 8, 2007, 03:00 PM
3.0charlie's Avatar
He's going for AMD, not Intel.
Hydro-Quebec is salivating...
Old December 8, 2007, 03:07 PM
BALISTX's Avatar
Maybe not I'm so tempted to get the E6750 on sale right now for $195 @ NCIX
Heatware
HWBOT
Old December 8, 2007, 03:10 PM
3.0charlie's Avatar
Well you were in your last reply! If you do, which mobo will be your choice?
Old December 8, 2007, 03:14 PM
"Quote This..."
What?
Why?
Can't help someone who doesn't want to help themslves.
  #19 (permalink)
Old December 8, 2007, 03:19 PM
BALISTX's Avatar
The Athlon 6000+ is $169 so for an extra $25.00 I can get the E6750 and get better results overclocking. I'm still going SFF so as for the motherboard, if I go Intel it will be the Gigabyte GA-G33M-DS2R.
I apologize for the confusion all, the only for sure thing is the RAM which I already bought. Crucial Ballistix Tracers PC-6400 @ NCIX for $83.00
Heatware
HWBOT
  #20 (permalink)
Old December 8, 2007, 03:23 PM
3.0charlie's Avatar
Great choice, since it can oc as well as the DS3L you had.
John
Antec 900 Paint and Design Suggestions JuggsJr Cases 10 January 10, 2008 01:53 AM
AMD offer 1/4 mill prize for architectural design competition Babrbarossa Off Topic 1 March 12, 2007 01:33 PM
Intel Tests Chip Design With 80-Core Processor Supergrover Press Releases & Tech News 0 February 16, 2007 01:19 PM
