Nehalem's Integrated Memory Controller Limitations/Benefits?
So I was in the realm of upgrading and building a new system and something I was looking into was with the Nehalem microarchitecture, as I'm going to be using probably an i7 930 or 950. One thing about these CPU's is that they now have an integrated memory controller, as opposed to it being on Intel's 'northbridge'. I figured this was all well and nice, but then I noticed that it supports triple channel 1066 RAM.
What I was wondering was, what if you used a memory of a higher frequency than 1066? I've seen plenty of systems with 1333, 1600 and so forth and I wonder what sort of downfalls this has. Is 1066 the optimal RAM for this chip? If so, how much of a benefit does it actually have over using a higher memory frequency such as 1600?
Any clarification on this would be much appreciated. I've read about many people having problems on all ranges of mobo's using these newer chips with their memory not being recognized or running properly and I wonder if this has something to do with it. I also want to make sure I'm ordering the optimal RAM for this processor, I originally was after using 3x2GB of 1600, but if 1066 works more latently, I'd sooner use 3x2GB of RAM to avoid problems.
