-   -   GIGABYTE GA-890GPA-UD3H vs MSI NF980-G65 Difference? (http://www.hardwarecanucks.com/forum/cpus-motherboards/35054-gigabyte-ga-890gpa-ud3h-vs-msi-nf980-g65-difference.html)
BiLLiO333 August 10, 2010 10:49 AM
Trying to building my first computer but I'm stuck at which Motherboard to get... I can't tell the difference between any of them. Can anyone help? :doh:
If anyone has any suggestions I'm open to them..
Case - Cooler Master 690 II
Processor - AMD Phenom IIX6 Processor 1055T
Video - nVidia GTX 260 Core 216
Fudd Rucker August 10, 2010 12:07 PM
One is an amd board with crossfire options (the gigabyte) and the other is an nvidia chipset with sli options (the msi)
I personally wouldnt touch an nforce based amd motherboard again ever in my opinion.
_dangtx_ August 10, 2010 12:36 PM
if you hook up with 2 gtx 460's and dont want to fiddle with drivers to get it going, 980a. dont know the boards much, could be brilliant or crap.
JD August 10, 2010 01:16 PM
Unless you ABSOLUTELY need SLI, don't buy the MSI. Get the Gigabyte. Great board, easy to setup, and the X6 1055T works out of the box. I setup one recently without issues.
BiLLiO333 August 10, 2010 04:13 PM
no plans for SLI so I'll stay with the GA890 another quick question.. do i need a seperate heatsink? i thought stock cooling would be fine but everywhere i go, people are installing heatsinks and all these additional fans...
JD August 10, 2010 04:27 PM
For the CPU? I'd say no. Stock cooling is quite adequate, though it does get a bit noisy once you run something CPU intensive or start gaming.
Most people either want to overclock or want absolute silence which is why they opt to replace the heatsink right away.
_dangtx_ August 10, 2010 04:49 PM
coolermaster 212+ all the way, worth the sub 25 dollar pm'ed price
Zero82z August 10, 2010 04:55 PM
If you want to overclock, get a good aftermarket heatsink. If you don't plan on overclocking, then there's no point in getting a different one.
