Old December 1, 2007, 01:24 PM
zlojack's Avatar
Default Q6600 Idle Temperatures
Hi all,
I just built my new rig (here's the thread) and I am somewhat concerned about the temperature of the Q6600, which is running at aroung 46-50 C at normal use...
Specs in my sig.
Should I wait for the Arctic Silver 5 to cure? Should I lap? (This would entail pretty much disassembling the entire rig to get the heatsink off. I should have made a hole in the mobo tray for easy heatsink removal...hmm.)
I'm pretty sure the heatsink is tightened down nicely...
EDIT: Sig's not working so here are specs:
Case - Antec 900
Mobo - Asus Maximus Formula
GPU - EVGA 8800 GTX
CPU - Q6600
RAM - OCZ ReaperX HPC PC28000 1000MHz (still waiting)
PSU - Coolermaster Exteme Power 650W
HD1 - Western Digital Raptor 150GB
HD2 - Western Digital SE16 500GB SATA2 7200RPM
Sound - Creative Labs Sound Blaster XtremeGamer Fatal1ty
Heatsink - Thermalright Ultra120
Monitor - Samsung SyncMaster 245B 24IN Widescreen 1920x1200
OS - Vista Ultimate 64-bit
Old December 1, 2007, 01:38 PM
donimo's Avatar
here is what my 6750 is at right now
so, yeah, yours is hot.
I would take the heasink off and make sure you have a nice evn coat of a good compound (thinner is better) and mounted right.
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old December 1, 2007, 02:35 PM
magictorch's Avatar
Default How are you measuring the temperature?
Is that idle using coretemp?
Old December 1, 2007, 04:02 PM
Eldonko's Avatar
Hardware Canucks Reviewer
50C is nothing to worry about. What are you using for temps and is that idle or load?
Old December 1, 2007, 04:11 PM
3.0charlie's Avatar
Is the Quad oc'ed? Are you sure that the HSF is sitting perfectly on the CPU? With all that weight pulling it down, contact may not be perfect. And again like others have asked, idle/load temps? And which software are you using?
John
Hydro-Quebec is salivating...
Old December 1, 2007, 04:57 PM
zlojack's Avatar
The programs that give me those temps are:
The stock Asus PC Probe II
Everest Ultimate.
I tried to install Core Temp but the drivers aren't signed so it won't work.
Both of those programs give me around the same temperatures.
That temp is at idle not under load. I haven't oc'ed yet, still setting up some of the details and learning the ins and outs of the BIOS.
I'm also getting a Mobo temp of 30 C
Old December 1, 2007, 08:44 PM
3.0charlie's Avatar
idle and stock? that's way too high. you have to find a way to install coretemp and make sure the hsf has good contact with the cpu.
Old December 1, 2007, 11:13 PM
zlojack's Avatar
Ok... I took off the heat sink and cleaned off the paste and looked at it with a razor blade and it was definitely not flat.
I lapped the base and now I'm getting 37 C, so that should hopefully come down a bit once the Arctic Silver breaks in.. also I think I might have used too much AS last time, so I used MUCH less this time around...(I actually did a test run to see how it would spread and it was much thinner with the new amount I used)
I still find the mounting to be loose in terms of being able to rotate, but it doesn't seem to have any play in terms of separating from the CPU....
I'll give it some time and see how it goes.
Old December 1, 2007, 11:29 PM
so i win :)
Intel C2D E6750 @ 2.7ghz
xfx 650i ultra motherboard
xfx 7600GS
Corsair 1GB DDR2-PC 5400
Seagate 320GB sata ll 7200.10
& 40GB
WD-250GB sata ll & 120GB
C-Master 430 watts psu
Sony DRU-830A
Antec Black spider case (9*80mm Fans)
1x120mm Aerocool xtreme Turbine,1x120mm Aerocool silver lighting.
Old December 2, 2007, 11:57 AM
donimo's Avatar
fair enough, you win, but mine is with a $17 cpu cooler, so I am happy even if it was 35 degrees.
Anybody know if core temp works wit vista yet?
when I install it it tells me it is XP only...
Wtb: Q6600 G0 m4xn00b Buy/Sell & Trade 0 February 29, 2008 03:41 AM
Accurate CPU temperatures? Below_Cost Overclocking, Tweaking and Benchmarking 8 February 6, 2008 03:17 PM
Oem Q6600 Brando737 CPU's and Motherboards 2 December 16, 2007 01:22 PM
New G0 Q6600 coldmeat CPU's and Motherboards 124 November 5, 2007 01:36 AM
New Q6600 Asspigeon Overclocking, Tweaking and Benchmarking 19 October 2, 2007 02:16 PM
