View Poll Results: What's your experience getting DDR3 to run stable on 790FX / 890FX?
Non AMD certified - No problems at rated specs 3 50.00%
Non AMD certified - unstable at rated specs 2 33.33%
AMD certified - No problems at rated specs 0 0%
Non AMD certified - unstable at rated specs 0 0%
Stock speeds (not OC'd) no problems with rated specs 0 0%
Stock speeds (not OC'd) unstable at rated specs 2 33.33%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Old August 1, 2010, 07:21 AM
sswilson's Avatar
Default 790FX / 890FX Memory issues?
Looking to get a feel for what kind of experience folks have had getting non "AMD Branded" DDR3 memory to run stable at rated specs on these two chipsets.
I've had experience with both chipsets, and it seems to me that the great majority of stability issues I've run into while OC'd have been memory related which required me to not only drop down to (2t), but also to loosen the timings a fair bit from the rated specs.
Rather than just go on my own personal experience (I could be doing something wrong.... ;) ), and ancedotal evidence on the motherboard forums I'd appreciate it if you'd provide your own personal experience.
Old August 1, 2010, 07:39 AM
stoanee's Avatar
Can you clarify "non AMD branded"?
heatware
Old August 1, 2010, 08:41 AM
sswilson's Avatar
There are many kits out there specifically branded for i5/i7, and a few sets are certified for AMD builds. The great majority of memory sets these days are intel certified, and that might actually be an issue due to secondary memory settings.
I suppose I should have said AMD certified instead of "branded".
Old August 1, 2010, 09:15 AM
Biff73's Avatar
I am using Team Xtreem DDR3-1866LV CL8 4x2GB with my 955 & Crosshair III 790FX,max mem speed I can run stable is 1720MHz on 8-8-8-24 timings,at 1800MHz it bsodHowever it fairs a lot better on a Core i7/P55 platform at max stable speeds at 2000MHz on 8-8-8-24 timingsYeah,Its an I5/I7 memory kit
Intel Core i7 5930K@4.6GHz@1.375v
Gigabyte X99 SOC
G-Skill Ripjaws4 X DDR4 2666 CL45 8x4GB@Stock
4x Zotac GTX 970 OC@1450/1850 SLI/with EK Full block Clear
Corsair 900D
Alphacool monsta 360 wc custom loop with 6 xGentle typhoon 1850rpm
Seasonic X1250 Modular 1050w 80+Gold PSU
2xWDC 1TB Caviar Black
OCZ Vertex 4 256gb SSD
RGB Led kit
Edifier S550 295W RMS 5.1 ch Speakers
Logitech G600 MMO Mouse
Ducky Shine 2
Old August 1, 2010, 11:49 AM
i always use whatevers on sale and is a good brand name. usually no issues, 790/890 as well.
890fx, which one ? rickbmb CPU's and Motherboards 3 August 1, 2010 01:09 AM
Which 890FX board will you be buying? BobbyLou CPU's and Motherboards 13 May 2, 2010 03:17 PM
790FX vs 790GX? CazyJimKU CPU's and Motherboards 7 July 6, 2009 07:06 PM
P5Q-E Memory issues Wurmer RAM 20 December 29, 2008 06:27 PM
