Old July 28, 2010, 07:02 AM
Prolab's Avatar
Default OC BE 965 + Gigabyte MA785GM-US2H
Hey Guys/Gals,
I've had this rig now for almost 8 months and decided to dwelve into OC again. I use this rig mostly for encoding movies and now playing SC2. I also recently bought CoolIT WC system and i thought i could squeze it to 4 ghz safely.
Well, ATM im currently running 3.8 ghz using the BIOS settings (19 x 200 mhz/everything else auto). Ive tried pushing it to 4.0 ghz but it keeps restarting. When i was cleaning up the goo off the processor/AC cpu heatsink, i cleaned it up with alcohol pads and coffee filter. Applied AC MX-3 using the pea size guide. I didnt see much difference (temp wise) according to speedfan (4 cores - 100%; 68C). Is that normal?
Im going to re-apply the thermal grease and see if that makes a difference. I felt like i messed up (i struggled installing the coolIT pump, trying to catch the backplate to screw in).
Can i safely OC this rig past 4.0 ghz? If so, is there a guide i can use to see if i can push it even further.
System Specs:
AMD BE 965
4 GB Kingston DDR2 1066
MSI 4890 T2D1G
BTW, i also messed up taking the CPU/heatsink out and end up bending 5 pins . Good thing my hands were steady and a mechanical pencil was at hand. I almost crap my pants bending the pins right back .
Old July 29, 2010, 09:23 AM
Biff73's Avatar
Have U activated ACC & Unleash yet?U might want to try going for 3800MHz with a different approach like what I did(225x17),can further increase NB/HT Link & memory bandwidth & speed,but u have to manually adjust the voltage thoughWindows will make it hard to boot into @4.0GHz,try doing it with AOD,afraid hitting 4.0GHz too often may fry your mobo
Intel Core i7 3770K@4.8GHz@1.375v
Asrock Z68 Extreme 3 Gen 3
G-Skill Ripjaws X DDR3 1600 CL9 4x4GB@1866MHz 9-8-9-24-36 2N
XFX 7970 Dual Dissipation GHz edition+Gigabyte 7970 OC@1300/1650 Crossfired
NZXT Switch 810 White
Corsair H70 Core with 2xGentle typhoon 1850rpm
Seasonic X1050 Modular 1050w 80+Gold PSU
2xWDC 1TB Caviar Black
OCZ Vertex 4 240gb SSD
Red & orange Led kit
Edifier S550 280W RMS 5.1 ch Speakers
Logitech G600 MMO Mouse
Ducky Shine 2
Old July 29, 2010, 11:57 AM
thats a healthy oc...but but..remember to properly drop some airflow around the socket area because
Old July 30, 2010, 10:37 PM
Prolab's Avatar
Well, re-applied the grease and didnt really made any difference in temps. It was no better than my old AC heatsink.
Anyhow, thanks for the recommendation. I did the timing manually (225 x 17, CPU volt = 1.47, memory = auto), but it was unstable for me. I end up using my old settings (200 x 19, everything else auto).
No, im reading through this forum:
Phenom II 550 + Gigabyte MA785GM-US2H = 1066? - Overclockers Forums
Is that a good start on values and tweak it a bit for mine?
BTW, im starting look for a DDR3 memory. Ive checked the website for the compatible memory list and i didnt see G.Skill on that list.
I was reading Is any memory tested for AMD? that AMD's usually are compatible on dual channel rather than triple.
Geez, ive been out of the loop in OC for years...
GIGABYTE MA790FXT-UD5P with AMD Phenom II X4 965 OC Performance Analysis windwithme CPU's and Motherboards 3 December 2, 2009 08:07 PM
can't connect HDMI and DVI on Gigabyte GA-MA785GM-US2H AMD785G redman CPU's and Motherboards 2 October 19, 2009 10:06 AM
