Old July 27, 2010, 11:16 PM
Default about temps for 955 on stock cooling
Hi,
what should the temps (idle and load) on the amd 955 BE edition be with stock cooling?
The room temperature is around 25 degrees and remains around that.
thanks in advance
regards
Unicorn11
Old July 28, 2010, 11:49 AM
Biff73's Avatar
Originally Posted by unicorn11 View Post
Hi,
thanks in advance
regards
Unicorn11
Is your 955 c2 or c3?mine's a c3,idles at 42c & max load at 56c.room temperature is 28c
Intel Core i7 5930K@4.6GHz@1.375v
Gigabyte X99 SOC
G-Skill Ripjaws4 X DDR4 2666 CL45 8x4GB@Stock
4x Zotac GTX 970 OC@1450/1850 SLI/with EK Full block Clear
Corsair 900D
Alphacool monsta 360 wc custom loop with 6 xGentle typhoon 1850rpm
Seasonic X1250 Modular 1050w 80+Gold PSU
2xWDC 1TB Caviar Black
OCZ Vertex 4 256gb SSD
RGB Led kit
Edifier S550 295W RMS 5.1 ch Speakers
Logitech G600 MMO Mouse
Ducky Shine 2
Old July 28, 2010, 11:07 PM
these are temps with the stock cooling or with the CM V8 Cooler ? yep its c3
Old July 28, 2010, 11:41 PM
it can vary on how you get the reading. c3's run the coolest, so 30-40's od;e are not that uncommon.
what matters are load temps. differences can be quite..large lol.
prime it and see what gives
Old July 29, 2010, 04:51 AM
my friends 955 idle was around 48 and load reaching 76 with stock cooling so is that on the higher side?
Old July 29, 2010, 07:44 AM
Biff73's Avatar
[quote=unicorn11;409102]these are temps with the stock cooling or with the CM V8 Cooler ? yep its c3[/quote
Its the temps with CM V8 Cooler,max safe temps for 955 c3 is 62c,your friend should be extra careful since it 14c hotter than max safe temp,wonder why your friend's CPU go off in smokeGot a friend that fried his 955 at 81c when OCing,AMD void his warranty
Gigabyte X99 SOC
Corsair 900D
RGB Led kit
Ducky Shine 2
Old July 30, 2010, 03:43 AM
my friend has not overclocked but his temps are still that high. So am guessing that he need to do something about the cooling then. Thanks all.
Old August 1, 2010, 09:05 AM
Biff73's Avatar
The AMD stock cooler is crap if you ask me,any entry level aftermarket cooler will solve his temp issue if he does'nt plan to PC
Gigabyte X99 SOC
Corsair 900D
RGB Led kit
Ducky Shine 2
Old September 30, 2010, 06:59 PM
Sorry, I'm new and late on this topic.. So I have a Phenom II x4 955 like you said.. and I'm just wondering whats going on with the cpu temp meter. Like what you guys said before, the after market fan should make it cooler. But after installing a cheap coolermaster hyper 101 it idles around 42c/43c and when on the load its about 56c/57c or around there. The stock AMD fan was 33c idle... loaded at 45c/46c. Whats going on here?? The AMD fan i think is 3300rpms, Aftermarket Fan is running at 2300rpm. could that be the reason?? What do you guys think?
Old September 30, 2010, 07:11 PM
If the aftermarket fan is bigger or designed to be quieter than the stock cooler then it will likely run at lower RPMs to as to not annoy your ears. However, that higher idle temperature tells me there's something wrong with your cooling solution. From the pics Hyper 101 - Cooler Master the Hyper 101 is a heatpipe direct touch which should give you a similar or cooler idle temp.
I'd try the following:
  • Run fan at full speed (disable BIOS control to fan or plug it straight to the power supply if you have an adaptor). Post idle and load temperatures for us to compare here.
  • If the temps are too high, I'd check the bond between CPU and heat sink. Is the heat sink seated properly, and is there too much or too little thermal compound applied?
PHENOM II 955 WATER COOLING metalcore Water Cooling 38 January 2, 2010 02:32 AM
Phenom II 955 BE Pukka Overclocking, Tweaking and Benchmarking 4 December 16, 2009 11:41 AM
Phenom II 3.7ghz with stock cooling Jonwall Overclocking, Tweaking and Benchmarking 8 February 25, 2009 11:35 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
E8400 Core temps - OCZ Vendetta 2 cooling Dwayne Air Cooling 8 August 17, 2008 01:13 PM
