Old July 24, 2010, 09:34 AM
not too smart. lol. many galons of water wasted.
Old July 24, 2010, 09:39 AM
JD JD is offline
I know somebody in the States that does this. Has all his blocks running through tap water. Constantly cold water entering so you don't need anything else really. I believe he opted for a reservoir + pump as a buffer of sorts.
Yes it's wasteful of water, but technically that water is all recycled and comes back to you at some point. He doesn't pay for water obviously (unlike most of us here).
Old July 24, 2010, 11:26 AM
hope he doesnt miss the water co's morning paper that reads 'all water will be off between such and such' :)
Old July 24, 2010, 11:59 AM
i'd be more concerned about the water bill while trying to tweak the settings. but sounds to me like your dad is just trying to get you work up
Old July 24, 2010, 03:05 PM
tell your dad to dig a trench n go geothermal
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old July 24, 2010, 03:25 PM
This just sounds like a big mess having hose running from the bathroom and back to drain. If you have a water meter it will cost more to run it like that then to get a newer cpu like others have said and to be honest its just a huge waste of water. Tell your dad bad idea and shell out for a new cpu.
Old July 24, 2010, 03:30 PM
MpG's Avatar
MpG MpG is offline
Unless I'm mistaken, open-loop cooling is against the law, isn't it? Not that it's actually enforced or anything, mind. Just sayin'.
Although, if the positioning was somewhat practical, there might be something to be said for running the house main inlet (in a copper pipe) through your reservoir. It wouldn't be consistent, but as long as something in the house was using water, it would get refreshed, and could help reduce heat dump within the room itself.
Old July 24, 2010, 05:59 PM
BootlegUsher's Avatar
While we are talking about novel water cooling set ups, would it be possible to run your tubing outside your house where the radiator could be located in order to take advantage of cold winter weather. If you lived in a part of the world where it only went down to 5-10 degrees in winter then the water would be nice and cold.
  #19 (permalink)
Old July 24, 2010, 07:07 PM
JD JD is offline
Yes. Many people do this. It can be equally effective even during summer months as you can just hook up f*ckin loud fans to it for massive CFM (assuming its far enough from your windows/doors).
  #20 (permalink)
Old July 24, 2010, 11:18 PM
I have also seen a video on youtube of a guy using a small deep freeze filled with some antifreeze and the radiator submerged in the antifreeze I can't seem to find it again.
#$%& My dad says... SiDiX007 Off Topic 4 May 30, 2010 02:52 PM
Ready For Motion Controls on PC? Valve & Razer thinks so! Thund3rball Gaming 8 January 11, 2010 07:28 PM
General Use PC for my Dad MarkOne New Builds 18 December 4, 2009 01:53 PM
HWC gets bigger, Corsair thinks so LCB001 Suggestions & Feedback 31 July 6, 2008 01:12 PM
OC'd a little 2 much me thinks. neophyte33 Overclocking, Tweaking and Benchmarking 8 December 2, 2007 01:30 AM
