Old July 20, 2010, 07:12 PM
Kommie986's Avatar
Default !!**URGENT**!! BROKEN CPU PIN ON MOTHERBOARD?
Hi guys. Just a few minutes ago, I took apart my rig and prepared to re-apply thermal paste tommorow. When I took out my Intel Core 2 Quad Q6700 from my Asus P5N72-T Premium, I noticed there was a screwed up pin on my CPU socket. I don't know if it's a broken pin or not. My CPU and motherboard were working perfectly fine before I took it apart. I'm not sure about now, but I saw it when I took it apart. PLEASE HELP! Below is the picture I took of it.
PS: My phone software is being gay on me, but It'll be up in a sec.
http://i26.tinypic.com/k4yryv.jpg
There
Old July 20, 2010, 07:21 PM
Originally Posted by Kommie986 View Post
ok so were looking at a bent or broken pin. put cpu back and see what happens. dont want to sound mean, but if it works dont fix it. or fix it when you have time and dont rush. get it up and folding if it works again.
Old July 20, 2010, 07:24 PM
martin_metal_88's Avatar
yup like dan said, just put it togheter and if the computer work fine keep it like that. If not, try to unbend it to the original position but this is pretty hard. if it was like that before you remove the CPU then it should work nice and sweet.
Old July 20, 2010, 07:26 PM
Kommie986's Avatar
UGH!!! My CPU was working fine before I took it out, and how is that that the moment I take it out, a pin bends?!!!
Edit: Working fine as in running at stock speeds with fine temperatures.
Old July 20, 2010, 07:28 PM
lowfat's Avatar
This. If you have to bend it back use the right equipment though. Make sure you have right tools though. You'll need a great magnifying glass and very precise tweezers. And even then it is very hard work.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old July 20, 2010, 07:29 PM
supaflyx3's Avatar
Socket pins are VERY fragile, even more fragile then the pins on old CPUs, the slightest touch will bend/snap one straight off.
Old July 20, 2010, 07:31 PM
some pins are not needed. lucky dog you! just make sure you mention it when you sell it.
Old July 20, 2010, 07:32 PM
Kommie986's Avatar
So it's confirmed broken/bent? =[ Will this affect overclocking results?
Edit: Could this have happened because I was using a pressurized air duster on my botherboard? I was getting some dust from some stuff and I might have accidently sprayed the socket.
Old July 20, 2010, 07:33 PM
only trial and error will confirm it. again, when you sell it do mention it :)
ps i wouldnt try oc'ing it if its fine at stock.
Old July 20, 2010, 07:35 PM
Kommie986's Avatar
Yeah, of course I will mention it. sakes. I jsut ed myself over for the next few months if I can't overclock.
URGENT HELP WITH MY CPU!!! NineLives Troubleshooting 18 July 12, 2010 11:18 PM
Is it possible to make cpu seem broken? xtreme1 CPU's and Motherboards 10 May 28, 2009 11:54 PM
6-pin PCI Express to single 8-pin no_pulse Power Supplies 12 July 8, 2008 04:46 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
8 pin or 4+4 pin CPU connection ? Unklmo CPU's and Motherboards 4 August 8, 2007 06:05 PM
