  #21 (permalink)
Old July 21, 2010, 11:41 AM
martin_metal_88's Avatar
Originally Posted by Zero82z View Post
Neither. Intel boards of late aren't great and you can't overclock. As for the Gigabyte, it uses DDR3. Martin's suggestion would be best.
Very good board. The only problem is that using a long video card in the second slot will block half of the SATA ports.
Wrong zero. The SATA port are just a little under so the sata cable will lick the videocard but fit. 2 Week ago I builded ( rebuild ) a client PC using this board and a GTX285 in the second PCI-e slot ( using the first for a SATA controller card. and the sata cable fit.
  #22 (permalink)
Old July 21, 2010, 12:49 PM
My P5Q Pro has the exact same layout, and when I tried to install my 65nm GTX260 in the lower PCI-E slot it completely blocked the top row of ports except for the one provided by the extra SATA controller.
  #23 (permalink)
Old July 21, 2010, 01:08 PM
Hm wierd...Is the cooler different in any way on 285 and 260 216?? or is your card bended a bit??? I don't know it's wierd. It was in a Dell with a Nvidia ( no brand GTX285 ) maybe there is any difference in the cooler.
  #24 (permalink)
Old July 21, 2010, 01:21 PM
source a used board, if need be. no way id buy a brand new retail priced board for a used system.
  #25 (permalink)
Old July 21, 2010, 01:30 PM
Maybe the 65nm version has a wider cooler.
  #26 (permalink)
Old July 21, 2010, 01:33 PM
see if the damn thing works first before considering a new board? XD
  #27 (permalink)
Old July 21, 2010, 01:36 PM
Anyway it's not really important since here OP run a single card XD
  #28 (permalink)
Old July 21, 2010, 01:41 PM
Kommie986's Avatar
I don't mind getting some sticks of DDR3.
Darn, I guess if it doesn't work I'll get the Gigabyte board and some new RAM.
Meh, if I upgrade to a CrossFireX board,it would give me an excuse to upgrade to a 5xxx series ATI card.
Oh BTW, I'm putting the stuff back together. I'll see if it works..
  #29 (permalink)
Old July 21, 2010, 01:46 PM
Why spend money that you don't have to?
You won't have any problems unless you're both using more than two SATA devices and using a large card in the second PCI-E slot. For your particular situation, it's not something you have to worry about. I was just mentioning it for the sake of it.
  #30 (permalink)
Old July 21, 2010, 02:58 PM
Kommie986's Avatar
I feel like the Spanish coach during the finals for this year's world cup during the 116th minute. :D
Edit: Thanks a lot guys. Though, I still feel like upgrading motherboards xD (ePen0r)
URGENT HELP WITH MY CPU!!! NineLives Troubleshooting 18 July 12, 2010 11:18 PM
Is it possible to make cpu seem broken? xtreme1 CPU's and Motherboards 10 May 28, 2009 11:54 PM
6-pin PCI Express to single 8-pin no_pulse Power Supplies 12 July 8, 2008 04:46 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
8 pin or 4+4 pin CPU connection ? Unklmo CPU's and Motherboards 4 August 8, 2007 06:05 PM
