Old July 20, 2010, 07:50 PM
martin_metal_88's Avatar
Maybe you should ask some local jeweler. They have really fine hand and if they can play in a watch they can sertainly un bend this baby. Just give them a call maybe they will help you. If not, I would suggest to do nothing because it's really hard to bend back as I already mention.
Old July 21, 2010, 06:34 AM
JD JD is online now
If I recall, some of these pins aren't exactly used, which is why things are working fine.
It's possible that it'll have no effect at all. Only way to find out is to try OC'ing and see!
Old July 21, 2010, 06:55 AM
jcmaz's Avatar
Originally Posted by Kommie986 View Post
Yeah, of course I will mention it. sakes. I jsut ed myself over for the next few months if I can't overclock.
Sell it on Craigslist!!!!
On a more serious note, just don't take the CPU out again.
-Plato
Old July 21, 2010, 07:04 AM
Kommie986's Avatar
LoL, no thanks. I don't want someone coming to my door and beating me up to steal my stuff. If it doesn't work (I'll find out in a few hours), then I'll just get the Asus P5N-T. Not as good as the P5N72-T Premium, but it'll work.
Old July 21, 2010, 07:46 AM
Well if you are buying a new board I would strongly sugest to get a P45 board. There are reason why Intel and soon AMD drop kick Nvidia for their chipset...If it's a board that lay somewhere at your home then go for it. Or if you are running sli and have no other choice then...
Old July 21, 2010, 08:16 AM
Kommie986's Avatar
What is the Intel Motherboard Chipset equivalent of the 780i?
Edit: No, I don't have any spare motherboards sitting around. I'm like a newby to computers. This was the first rig I ever built, and it was with the help of my friend.
Old July 21, 2010, 08:26 AM
Well a P35 would be way better even if it's no more on sale. P45 is the one to get actually. You can have some good'n cheap P45 or look here at HWC in the BST section. Some member have good board for sale maybe. The main difference between 780I and P45 is that the P45 don't suport sli but if you are running a single card then it dosen't matter. GL
Old July 21, 2010, 08:29 AM
Kommie986's Avatar
Which of the following two boards would you recomend?
Buy the Intel DP45SG Motherboard at TigerDirect.ca
or
Newegg.ca - GIGABYTE GA-EP45T-USB3P LGA 775 Intel P45 USB 3.0 ATX Intel Motherboard
Thanks for all your help guys, especiall you Martin.
  #19 (permalink)
Old July 21, 2010, 08:41 AM
I would go for the gigabytes myself or this one
Buy the Asus P5Q Pro Turbo Intel P45 Socket 775 Motherboar at TigerDirect.ca
We sell alot of it at my job for replacement and it have been good so far.
  #20 (permalink)
Old July 21, 2010, 11:16 AM
or
Neither. Intel boards of late aren't great and you can't overclock. As for the Gigabyte, it uses DDR3. Martin's suggestion would be best.
Very good board. The only problem is that using a long video card in the second slot will block half of the SATA ports.
URGENT HELP WITH MY CPU!!! NineLives Troubleshooting 18 July 12, 2010 11:18 PM
Is it possible to make cpu seem broken? xtreme1 CPU's and Motherboards 10 May 28, 2009 11:54 PM
6-pin PCI Express to single 8-pin no_pulse Power Supplies 12 July 8, 2008 04:46 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
8 pin or 4+4 pin CPU connection ? Unklmo CPU's and Motherboards 4 August 8, 2007 06:05 PM
