Old July 17, 2010, 06:46 PM
Default What's the point of getting the Asus M4A89GTD Pro/USB3 over the normal one
It's $10~$20 more expensive, and the only difference between the two is one has USB3 ports and the other one doesn't. But if USB3 is backwards compatible with USB2 then what's the point of getting the more expensive version?
Old July 17, 2010, 07:28 PM
gambel626's Avatar
USB3 is the only reason that it's more exspensive. At the moment There are not that many devices that support USB3 but those that do get much better speeds then the conventiional USB 2.0 but esata is still the fastest. If I had the money I would buy the USB3 version but if you don't you can always buy an add in card at a later time.
If it Ain't Broke, Hit it Harder
Old July 17, 2010, 08:37 PM
ZZLEE's Avatar
USB 3 is 10 times faster data transfers than USB 2 and has 3 to 4 times the power fore charging devices like Iphone .
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Asus Shows Off P7P55/USB3 Motherboard with USB3.0 Header FiXT Press Releases & Tech News 0 July 16, 2010 11:22 AM
ASUS P7P55D-E Pro AI Tuner in the Bios GMJim CPU's and Motherboards 1 March 6, 2010 07:16 AM
ASUS M4A89GTD PRO Series Motherboard Featuring Core Unlocker FiXT Press Releases & Tech News 0 March 3, 2010 11:30 AM
FS: New Asus P5Q Pro Motherboard cms Buy/Sell & Trade 8 August 31, 2008 12:51 PM
Asus p5wdg2 ws pro help maurier CPU's and Motherboards 0 June 23, 2008 08:24 PM
