Old July 16, 2010, 08:12 AM
Default worth it to upgrade from x3-720 to X4 955?
Hey all, im debating upgrading from my trusty tri-core phenom2 X3-720 (6mb cache) overclocked to a respectable 3600mhz, to a quad core phenom2 X4 955 (8mb cache). I'm sure the x4 will do 3700-3800 overclocked, but is it worth all the trouble? in all the benchmarks @ stock speeds the x3-720 is only a few fps beneath the x4 955.:p If i bought the x4 955 used for $140, sold my X3-720 for say $90, its a $50 upgrade. but is it worth all the hassle? Will i notice much of a diff from the extra core and the extra 2mb cache of the 955? thanks in advance for any feedback.
X6-1100T @ 3.8ghz w/ TT Frio @ 1400rpm @ 1.375v & 2.8ghz CPU/NB @ 1.35, 8GB Patriot DDR3 @ CL9-9-9-24, Gigabyte 970A UD3, Gigabyte Windforce OC GTX 670, Samsung P2770 @1080p, 64GB C-300 SSD & 2TB WD Black, X-FI gamer, Corsair HX520wt psu, Corsair 600T case, Win7 64
Old July 16, 2010, 08:19 AM
Lpfan4ever's Avatar
I'd say if you were gonna upgrade, the only place you'd see a bit of a change is going to the 1055T or1090T.
Originally Posted by encorp
Code:
<firebane> slightly used
Old July 16, 2010, 08:36 AM
fishingfanatic's Avatar
Smile CPUs and Motherboards
+1 with Ipfan4ever. Wait a little for the extra coin, then get either 6 core.
Old July 16, 2010, 08:37 AM
that's what i thought. but even then i dont think those amd hexa-cores are the most efficient designs, i mean a 6 core cpu w/ only 9mb cache?:p
Old July 16, 2010, 08:50 AM
geokilla's Avatar
+1
Can your 720 be unlocked?
Old July 16, 2010, 08:52 AM
nope, my mobo doesnt support that.:(
Old July 16, 2010, 03:23 PM
jcmaz's Avatar
No, i would get something else instead. IE: new video card or SSD?
-Plato
Old July 16, 2010, 03:27 PM
keep it unless you need it for folding.
Old July 16, 2010, 05:55 PM
yea im looking @ SSD's as my next upgrade. cheers folks.
Is it worth the upgrade? Agafaba Display Units 1 May 27, 2010 12:36 PM
Worth the upgrade? Nevakonaza New Builds 8 May 11, 2010 11:31 AM
Worth the Upgrade..? r0k0 O/S's, Drivers & General Software 8 February 9, 2010 07:03 PM
core 2 to i7 is it worth the upgrade? magictorch CPU's and Motherboards 25 December 3, 2008 08:28 PM
Opteron 165 to an e5200 worth the upgrade? vulcan500rider CPU's and Motherboards 17 November 1, 2008 10:54 AM
