Old November 25, 2007, 08:38 PM
Rapid-X's Avatar
Default Huge Vista Error
ok installed vista home basic yesterday .. Now i get a 5.1 score for my processor (dual core 4800+ 2.5) but a friend of mine has a 3800+ single core and gets a a 5.8 i think. take a look at this picture any ideas how to fix it ????
Old November 25, 2007, 08:42 PM
MpG's Avatar
MpG MpG is offline
I'm pretty sure the score doesn't go past 6.0.
Old November 25, 2007, 08:53 PM
Judging by the pic he posted, I think he's trying to figure out why his 2nd core is not functioning.
As for how to fix it, I've never run into an issue like that. Have you downloaded the latest driver off of AMD's website ? Have you clicked on the Check for Solutions button ?
Old November 25, 2007, 08:55 PM
Score doesn't go past 5.9
Old November 25, 2007, 09:15 PM
Rapid-X's Avatar
tried nothing happened , checkin amds website rite now no luck so far
Old November 25, 2007, 09:27 PM
MpG's Avatar
MpG MpG is offline
The post originally said 6.1. And even a 5.8 seems pretty impressive for a single core CPU. But no matter.
I know I'm reaching here, but are there any options in the BIOS to disable cores?
Old November 25, 2007, 09:33 PM
"Quote This..."
Here's your solution:
How to install the AMD X2 drivers, hotfix, the correct way. - XtremeSystems Forums
Old November 25, 2007, 09:59 PM
No way he gets 5.8 with that, unless it's clocked somewhere around 4 GHz.
Does clicking check for solutions do anything useful? To be honest, I'd probably just reinstall at that point, since you only installed it yesterday.
Correct, MS plans to extend the score by 1.0 (so to 6.9 next) at periodic intervals, when they feel the need, I think they said every 12-18 months IIRC.
Originally Posted by Squeetard View Post
Don't do that, they're specifically for XP, there aren't any drivers or hotfixes available from AMD for Vista.
Old December 1, 2007, 08:21 AM
I'm not 100% sure but I thought I read somewhere that Vista Basic does not support more than 1 core..
AS part of the limitations of Vista Basic..
Like I said not 100% sure..
Intel i7 920 Stock Speed
Corsair H50 Hydro Cooling Kit
ASUS P6T Deluxe V2 Motherboard-
1 Powercolor HD 5850 1Gig Card
6 GB Patriot Viper 1600-
Antec P182 Gunmetal Grey Case
5x1TB BlackWestern Digitals -
2X PIONEER DVR-212D DVD-RW - 24" Samsung 245T LCD -
OCZ Game X Stream 600 -
WINDOWS 7 Premium 64BIT
Old December 1, 2007, 12:05 PM
Vista Basic doesn't support "multiple processors" it works fine with "multiple cores"
Huge FT list Wanted: Sata drive, pci-e vid card, 24 pin ps, ddr, etc nork Buy/Sell & Trade 18 May 15, 2008 07:20 AM
Vista Ultimate x64 STOP Error tehgooch Troubleshooting 11 April 26, 2008 08:02 PM
Vista error biff Troubleshooting 3 March 2, 2008 07:46 AM
First custom system, hd error Can't install Xp or vista zffarooq Troubleshooting 2 November 3, 2007 01:26 PM
