Originally Posted by buddyman If you are not worried about warranty's & If your case is Wide enough
Try an aftermarket coolers > this very web site has three of them &and one of them
I have on my i5 750 @ 87f cpu temps are 36c to 38c idel work loads 45c to 48c
your temps are very good. besides if its 120 inside A cooler can only do so much |
Hi there.
I have given a great deal of thought to installing a new aftermarket cooler. The heat down here -- especially in the dry season -- can be lethal. It will be sometime, though, until the dry months come again, and by then the warranty would have lapsed so I'll be looking around for a good CPU fan.
Any suggestions? My PC case is a Cooler Master Elite 335.
Thank you very much for your input.
