Old July 1, 2010, 08:24 PM
bvsbutthd101's Avatar
Default I am completely stupid
I went to overclock my CPU to 3.6 ghz and I think I went to high on the voltages
Now when I try to turn my computer on nothing comes up on the screen so I can't change the voltages
I've tried everything, taking the cpu out, removing the battery on the motherboard,
and a couple other things, I just can't seem to get it to go on
Can anybody help me?
Old July 1, 2010, 08:50 PM
stoanee's Avatar
Reset CMOS yet?
heatware
Old July 1, 2010, 08:51 PM
waiiit a minute
it doesnt turn on right?
if you already took those steps...hmm....take the whole thing out and put it together on thine table.
try again. reseating the other components,removing mobo from case(i.e. unplugging power supply) might do it
edit : oh you got a 750i mobo? theyre much better stability wise than teh 6 series, but still not up to par with other contemporary mobos(its a bios thing...)
that or you killed something
how much juice?
Old July 1, 2010, 08:57 PM
Originally Posted by _dangtx_ View Post
waiiit a minute
how much juice?
heres the voltages i used
vcore 1.4375
dram 2.1
ht 1.48
nb 1.48
sb 1.60
Old July 1, 2010, 11:08 PM
sb 1.6? hmmmmmmmmm
*breaks open a manual.........
Old July 1, 2010, 11:10 PM
jcmaz's Avatar
I'm no wiz at Nvidia boards but that sounds a bit too high...
-Plato
Old July 1, 2010, 11:25 PM
was thinking the same,having been corrupted by inhell mobos :D
. looks like its nothing,or close to nothing lol
ASUS P5N-D Mainboard Review (page 7) - X-bit labs
Vcore Voltage parameter can be adjusted from 0.83125V to 1.6V with 0.00625V increment. Other voltages can be changed with 0.02V increment in the following intervals:
  • DRAM Voltage: 1.85-3.11V;
  • HT (HyperTransport) Voltage: 1.2-1.96V;
  • NB Chipset Voltage: 1.2-1.76V;
  • SB Chipset Voltage: 1.5-1.86V.
These are pretty wide ranges, the increment is quite small and the parameters can be changed very easily. For example, just select one of the parameters and you will immediately see the supported range in the right-hand side of the screen.
For the CPU Vcore you will see not only the supported voltage interval but also a special warning. It will remind you of a well-known ASUS mainboard issue: any changes to the processor Vcore when it is not longer set to Auto mode will disable all power-saving technologies.
It is great that they admit to having this issue and honestly warn the user about it, but I wish they had resolved it instead.
Old July 1, 2010, 11:43 PM
Caldezar's Avatar
Reset CMOS should bring you back to defaults. Then you should be golden. If that doesn't help, you have bigger fish to fry...
Old July 2, 2010, 02:13 AM
sswilson's Avatar
What hardware is this for? Unless I'm missing something HT is for AMD systems.
Old July 2, 2010, 06:17 AM
It's an intel system
ok this is just stupid gingerbee Off Topic 24 November 26, 2009 10:16 AM
Now for something completely different! Chilly Off Topic 4 November 3, 2009 09:08 AM
is it possible to build a completely Identicle comp and join them together Shadowmeph New Builds 5 March 21, 2009 07:41 PM
How to completely wipe out F@H and start a new? Silvgearx HardwareCanucks F@H Team 3 March 16, 2009 02:45 PM
I'm back and I'm stupid Babrbarossa HTPC Systems & Software 12 September 26, 2008 01:48 PM
