  #21 (permalink)
Old July 19, 2010, 12:06 PM
Arrow
As other suggested I would try reset CMOS, but not by removing battery but by shortening dedicatory pins or switching switch. MB could have capasitars to give temporary energy even with dead (or without) battery.
  #22 (permalink)
Old July 19, 2010, 01:44 PM
Is the video cable loose? Monitor power is on? Is there a beep when you first power on? If you do not have another video card to swap, then try and connect to a tv.
  #23 (permalink)
Old July 19, 2010, 07:07 PM
bvsbutthd101's Avatar
Little late dude, I already got my new hardware and it works so much better. so my faster then my old stuff. plus I tried all that, none of it worked.
  #24 (permalink)
Old July 21, 2010, 02:13 AM
bottle's Avatar
Since you got your new stuff, you might want to make a post to sell your old (preferably working) parts.
  #25 (permalink)
Old July 21, 2010, 07:35 AM
yea I probably will
ok this is just stupid gingerbee Off Topic 24 November 26, 2009 10:16 AM
Now for something completely different! Chilly Off Topic 4 November 3, 2009 09:08 AM
is it possible to build a completely Identicle comp and join them together Shadowmeph New Builds 5 March 21, 2009 07:41 PM
How to completely wipe out F@H and start a new? Silvgearx HardwareCanucks F@H Team 3 March 16, 2009 02:45 PM
I'm back and I'm stupid Babrbarossa HTPC Systems & Software 12 September 26, 2008 01:48 PM
