  #31 (permalink)
Old October 17, 2010, 02:56 PM
you can get away with using cheaper sinks for them fets. theres a pack of 12 i believe for 5 bucks at ncix, older tipe not as good as enzotech but hey.
  #32 (permalink)
Old October 17, 2010, 03:35 PM
Patramix's Avatar
i am getting the Enzotech MST-88, at 15$ not gona bother trying to install smaller sinks.
just need to convince myself of witch ram to buy now.
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
  #33 (permalink)
Old November 1, 2010, 10:04 AM
arbb5's Avatar
Great Review!! I just bought this board based on the review here and I love it!! I will be modding a cooler from an old Thermaltake Volcano 7+ that I have kicking around for the Mosfets.
Bought this along with a PII 555BE and 4GB G.Skill F3-12800CL8D Ram with the Scythe Yasya to keep it all cool, successful unlock of other 2 cores, raised multiplier to 18 to hit 3.6mhz stable without increasing stock volts of 1.4 and still running a cool 39c under load.. :) haven't tried to go higher yet, I will in time but for now I am extremely happy with this setup!! beats the hell out of my old faithful Opty165@2.6ghz that it replaced!!
Phenom II X2 555BE Unlocked to X4@3.6ghz / GA-870A-UD3 / 4 Gig (2x2GB) G.Skill F3 Ripjaws / EVGA GTX260 / Skythe Yasya / Tagan 2 Force II 600W
  #34 (permalink)
Old January 22, 2011, 12:36 AM
Trial Member
Hai evryone i'm a new user, i also use the GA-870A-UD3 MoBo...its great, can support Phenom II X6 processor and can support up to 16Gb DDR3 RAM, also can put 2 PCi-e card for crossfire...haha..nice MoBo for intermediate gamers....
Now im using the Phenom II x4 955BE 3.20Ghz, ATI RADEON HD5770 Flex Edition....
  #35 (permalink)
Old February 25, 2011, 12:48 PM
Trial Member
So what ram are people using with this MB?
I have Asusu M2N32 right now with 2gig DDR2-800 and will be upgrading to this Gigabyte GA-870A-UD3.
My upgrade path started by swapping out my Athlon X2 6000+ for a Athlon II X4 640 both at 3.0GHz.
Then I replaced my EVGA GTS 8800 320MB GPU with a Gigabyte GeForce GTX 560 Fermi 900MHZ 1GB.
I sure notice my Ram and 1000Mhz HT bus is holding my back on this good but old mother board. So I'll be getting this MB and DDR3 ram, Maybe a 64-120 Gig SSD if I can swing it!
Should I get 1866MHz ram and will it run at that speed, or does everything need to be OC'd to make it run that fast? Or do I just get 1600 or 1800 MHz sticks. I plan on 2x4Gig or 2x2Gig dual channel setup. I will likely purchase from NCIX online or any others in Vancouver, BC area.
Thanks,
Lee
GIGABYTE GA-MA770-UD3 Motherboard Review Comment Thread MAC CPU's and Motherboards 16 August 13, 2011 01:10 AM
MSI 790FX-GD70 AM3 Motherboard Review Comment Thread SKYMTL CPU's and Motherboards 16 July 29, 2009 11:30 AM
Gigabyte GA-EP45-DQ6 Motherboard Review Comment Thread MAC CPU's and Motherboards 15 September 2, 2008 09:51 PM
