Old August 5, 2010, 01:53 PM
Eldonko's Avatar
Hardware Canucks Reviewer
Welcome to the team bro
Old August 5, 2010, 02:31 PM
if you have proper airflow and dont go crazy on the voltages you should be fine. altough remember the 1055t will eat a good ~200 watts more when heavily pushed so..:)
if you do order, i sugest enzotech.
Old August 5, 2010, 07:16 PM
Ok, thanks for the reply guys, now im worry if my OCZ GameXStream 600w will be able to handle my new system :P
I have a Toxic 5850@ 850/1135 (i edit the bios with RBE) and a 9600gt Zotac Eco that i used for hybrid Physx in my old rig with an Ecs 790gxm-ad3 and a Phenom II x3 720 @3.6ghz, i just changed the motherboard to this gyga and 720 for the 1055t but with Oc maybe my PSU will fail
Old August 5, 2010, 08:11 PM
Oversized Rooster's Avatar
I've had some trouble with the 870A-UD3 mobo. I was going to use a 4GB G.Skill DDR3-1600 7-8-7-24 but found comments online with people saying that this kit won't run at CL7 almost no matter what.
Then I used a 4GB G.Skill DDR3-1600 CL7 Eco kit which was published as being specifically compatible with this mobo. Wrong again. I had to set the timings manually and instead of 1.35V, I had to use about 1.42V. That wasn't 100% stable either.
In two words...this mobo has been super picky with RAM.
Machine: Intel 6800K | Asus X99-E | 32GB Corsair DDR4-2666 | 500GB Samsung 960 EVO NVMe | 6TB WD Black | 2 x 4TB Hitachi 7K4000 | Corsair 750D | Seasonic XP-860 Platinum | 4GB GTX 970 G1 Windforce | 2 x 27" Samsung S27D390HS PLS | Win10 Pro 64-bit
Old August 5, 2010, 08:31 PM
very interesting.usually youd expect asus boards or something to pick out on ram...could be chipset/timings related?
and that psu will be ok, unless you push some mad overclocks.
Old August 5, 2010, 09:27 PM
Thanks dangtx, ive already think about it and i wanna get 3.8 @ winter and 3.6 @ summer :P, when i change my psu and get better cooler than my ocz vendetta 2 ill try some insane oc, thanks again for the help ^^ i hope have luck so i dont have to put 1.5v xD
Old August 5, 2010, 09:39 PM
1.5 is for around 4 gigs if i recall correctly.
vendetta II is not a bad cooler, altough kinda low end nowadays.
thanks the reviewer, i spotted this beast thanks to him. knowing giga boards though, just a glimpse at the socket area + price of around 100 bucks would make it a no brainer :)
Old August 7, 2010, 01:39 PM
Originally Posted by Oversized Rooster View Post
I've had some trouble with the 870A-UD3 mobo. ... G.Skill ... G.Skill ...
mother f...ather. gonna assemble mine next weekend and bought some g-skill not on the supported list only cuz it was on sale
  #19 (permalink)
Old August 8, 2010, 02:22 AM
Hi Raxen, I recently bought one mostly based on your review but i am very disappointed, I run the m/b with 4gb ocz gold pc10666 ram and x3 440 cpu, i hardly can go more than 230 in fsb without having core stopped at 1-2 min in prime... the m/b unlocks the 4th core but if i try to test with prime i should have my ram at 1066 or will have workers stopped after 1 min...can u pls tell me the settings you had when o/c the unlocked phenom...tnx in advance
  #20 (permalink)
Old August 8, 2010, 05:59 AM
sswilson's Avatar
First thing to try would be to see if you have the same fsb issues without the core unlocked. If you don't, it's very likely that the extra core is what's holding you back.
Are you downclocking the other settings when you bump up the FSB (NB / HT / Memory)?
GIGABYTE GA-MA770-UD3 Motherboard Review Comment Thread MAC CPU's and Motherboards 16 August 13, 2011 01:10 AM
MSI 790FX-GD70 AM3 Motherboard Review Comment Thread SKYMTL CPU's and Motherboards 16 July 29, 2009 11:30 AM
Gigabyte GA-EP45-DQ6 Motherboard Review Comment Thread MAC CPU's and Motherboards 15 September 2, 2008 09:51 PM
