Old June 27, 2010, 08:47 AM
Charmster's Avatar
Default GA-890FXA-UD5 - Help! Bios Updating
Hello,
How do I update my bios? I have downloaded the files but I have no idea how to "install" it. Can anyone help me out?
System Specs:
AMD Phenom II x4 965BE @3.6GHZ
CM 690 II Advanced
CM Hyper 212+
Corsair TX750W PSU
Gigabyte GA-890FXA-UD5
G.Skill Ripjaws F3-12800CL7-2GBRM - 4GB
EVGA GeForce GTX 650Ti Boost
Old June 27, 2010, 08:53 AM
hey. you can use the giga utility in windows, or at boot. if its super stable, kill other processes and do it in windows.
Old June 27, 2010, 10:05 AM
Charmster's Avatar
Where do I find this giga utility? How do I do it in bios? Like I have the files, but they are on my desktop and I don't know how to access them when I am in Bios.
System Specs:
CM 690 II Advanced
CM Hyper 212+
Corsair TX750W PSU
Old June 27, 2010, 10:12 AM
Supergrover's Avatar
Saves me typing it all down.
Link:How to Update Your Computer's BIOS - wikiHow
R.I.P.
Old June 27, 2010, 10:31 AM
GA-890FXA-UD5 (rev. 2.0) - GIGABYTE
bios, @bios
used it a lot
as long as pc is not overclocked and mighty stable(might want to plug it into a battery backup before) youll be fine
Old June 27, 2010, 10:33 AM
martin_metal_88's Avatar
You can find the GA software on your GA driver disk. This soft work like a charm and is really helpfull for bios upgrade.
You can also get it here it's the @bios utility
Edit : Damn dan have been bit faster then me
Gigabyte GA-890FXA-UD5 Revealed Soultribunal Press Releases & Tech News 8 March 9, 2010 05:29 PM
P55 UD4P or UD5 fuzman CPU's and Motherboards 3 December 11, 2009 04:28 PM
Got my GA-UD5 back from RMA Sagath Troubleshooting 0 September 28, 2009 02:54 PM
GA-x58-UD5 and i7 920 zlojack CPU's and Motherboards 136 December 17, 2008 01:46 AM
