-   -   PLEASE HELP - USB transfer rate very SLOW !!!!! (http://www.hardwarecanucks.com/forum/cpus-motherboards/33555-please-help-usb-transfer-rate-very-slow.html)
torque.vortex June 24, 2010 09:20 AM
I just built a new rig :-
CPU - AMD Phenom II X4 965 BE
MOTHERBOARD - ASUS M4A88TD-V-EVO-USB3
GPU - XFX RADEON 5770 1GB
PSU - COOLER MASTER 550GX
COOLER - COOLER MASTER HYPER 212+
CASE - COOLER MASTER USP 100
HDD - 1TB Seagate SATA 3.0
RAM - OCZ gold 1333MHz 4Gb (2*2gb)
The problem is, im getting really low transfer speeds between the HDD and usb drives (slowest with my ipod) even though i'v tried connecting them to the USB 3 socket, and iv also tried changing the hardware settings of the Removable disks to Optimize Performance, but the transfer rate doesnt seem to increase at all, i get a transfer rate, roughly around 10mbps (~3gb in 5 mins). And while transferring around 50 gb from my ipod, it took almost an hour and a half, and even deleting stuff from the Removable disks takes a lot of time.
I'v even checked the BIOS settings, and the USB 2.0 is set to HiSpeed.
So have any of you guys with the same motherboard experienced the problem??
Any fix to this??
Where can the problem be?
Alpine June 24, 2010 11:15 AM
Do you have the setting for FULLspeed ?! If i remember right, on my P5K SE i need to put on FullSpeed
torque.vortex June 24, 2010 11:53 AM
FULLspeed is stated at only 12mbps, whereas HiSpeed is stated at 480mbps, so I din't bother trying that out.
Silvgearx June 24, 2010 09:22 PM
USB2 or USB3 don't matter, its probably your device. The larger the flash drive the slower they are.
torque.vortex June 25, 2010 12:51 AM
its the same with my ipod (80gb) and my 2gb pendrive, i even did some benchmark tests and the max read speeds i got was 15mbps and max write was ~14mbps
so where do guys think the problem lies?
ForTheGG June 27, 2010 01:08 PM
That's about what I'd expect from USB devices of that caliber. My Sandisk 16GB gets a max of 26 mb/s.
Smoothie June 30, 2010 07:29 AM
Set it at Fullspeed and compare.
bojangles June 30, 2010 08:40 AM
I have slow transfer speeds too. Totally depends on the controller in the device.
