Old November 21, 2007, 03:49 AM
Default Trying to choose a motherboard/chipset
I dont know which chipset to go with for my Q6700 2G 5-5-5-15 OCZ and 2x XFX 8800 GT 512.
Cards are on order as well as CPU, time for an update.
3 Choices are Intel's P35 , X38 or Nvidia's 680i.
Im getting confused reading articles and input from different people, basically I was going SLI 8800 GT's but I changed my mind to just stay with a single 8800 GT card an go with a good stable board/ chipset.
The P35 is suppost to be very good, stable although seems like its past its prime (from what Im reading)
The nvidia 680i is best for video although overheats and isnt stable (please correct me if this is wrong).
The X38 is newest and the only chipset with PCI-e2.0 at the moment, some advantage for my 8800 GT i guess.
Any feedback would help.
Old November 21, 2007, 10:13 AM
"Quote This..."
Intel chipsets will not have SLI only crossfire. I am happy with my p35 (Asus p5k-premium). The 680i had all kinds of Sata/raid issues so I stayed away from it. I think they are sorted out now.
Old November 21, 2007, 10:38 AM
680i only had issues at the very beginning when they emerged. Now the 680i chipset is very strong and very good and its what I use.
Old November 21, 2007, 11:55 AM
What about having PCI-e 2.0 as an option, would that not help with the new 8800 GT's for single card use?
Im just not sure if I should go SLI or not, I have the option just not sure for the money if its worth it.
When I look at most games its not much faster than a single card and in some cases at high res looks like 30% performance increase.
Any feedback from SLI users in here, what do you think?, is it worth it?
Old November 21, 2007, 12:39 PM
magictorch's Avatar
Default its difficult
For SLI it really depends if your willing to sacrifice the price:performance ratio right now.
There will be newer more powerful single card solutions to upgrade to next year instead.
My brother uses 8800GTX's in SLI and it does make a difference-but as the performance increase is not doubled or even enhanced by 25% you have to really pay over the odds for that extra % boost. Plus there are driver issues to iron out.
As for mainboards:
NO SLI on Intel chipsets
Critically it maybe hard to find nvidia chipsets that support the new intel cpus. This is a real problem.
X38 has just been released and is therefore expensive. They also have some bugs to iron out from the reviews I have read of the ASUS or gigabyte X38 boards. You can get DDR3 and the price will drop on this next year, but you will have to payout $450 or so if you want it now. You could always go DDR2 in X38 which just leaves you with pcie2.0 as the main reason to get the board over the P35.
PCIE2.0 is unlikely to make much difference when using one card only.
P35 does not have the latest features but they are a solid price/performance option that natively support the latest intel cpus and are good at ocing current quads. They will likely OC the new quads nicely and with one of next years best cards I doubt the PCIE*16 lane will be saturated. Come 2009 you will want to upgrade though to DDR3 if you dont buy a DDR3 P35.
Its not an easy time to buy. Intel has bulldozed AMD out of the way and clamped down on NVIDIA's share of the mainboards so your options are more limited but still good.
Old November 21, 2007, 01:51 PM
Choices in motherboards are:
Asus P5N32-E-SLI 680i chipset
Asus P5E x38 chipset
Asus P5K Deluxe P35 chipset
Asus P5K-SE P35
Old November 21, 2007, 02:16 PM
Asus P5K-SE P35
I have the P5N board and its great but I'm holding out for the 780i to see how well it does, but you can't go wrong with any of the p35s and I'd not go with a X38 yet.
Old November 21, 2007, 02:53 PM
Which chipset do you have, 680i or 650i ?
Have you overclocked, is it stable, any compatibility or overheating issues?
Old November 21, 2007, 03:25 PM
680i mines the P5N32-E SLI board. Yes its overclocked with a e6600 running at 3.4ghz 100% stable and 4gb of Team Xtreem memory at 2.1v with absolutely no problems whatsoever.
Old November 21, 2007, 03:49 PM
I guess your running a single xfx 8800 GT for the moment?
Would you personally bother with another 8800 GT for the extra money or you happy with how this performs as is?
What to Do - which to choose janes780 RAM 5 December 10, 2007 12:34 AM
Good AMD/Ati 580x chipset Motherboard? qwerty CPU's and Motherboards 1 October 26, 2007 01:06 PM
help to choose best psu for x1950pro Real_DeaL311 Power Supplies 10 October 17, 2007 05:47 PM
PC Perspectives reviews: Asus P5N32-E SLI Plus Hybrid Chipset Motherboard Babrbarossa Reviews & Articles from the Web 2 March 6, 2007 08:40 AM
TweakTown Has DFI ICFX3200-T2R/G Motherboard AMD RD600 Chipset Arrives! Supergrover Reviews & Articles from the Web 2 January 9, 2007 08:29 PM
