Old June 14, 2010, 07:32 PM
Black_Ice-Dragon's Avatar
Default 1055T X6 only 2 cores!
Hey guys just installed my new 1055t tonight, though I am having an issue. Ive tried loading down my cores but the cpu is always running in 2 cores at 3.3ghz. I did the bios update for my board.
My specs are :
AMD 1055T X6
Gigabyte MA770-UD3 Rev 1.0
4gb Patriot DDR-800
xfx 4850.
Anyone got any suggestions?
Old June 14, 2010, 07:36 PM
MacJunky's Avatar
Try an app that can load a higher number of cores.
Old June 14, 2010, 07:38 PM
Just gave wPrime a run with 6 threads and still only 2 cores.
Old June 14, 2010, 07:39 PM
shaw
Guest
Posts: n/a
Make sure BIOS shows Cores as available, and that BIOS can recognize the 6 core chip.
Old June 14, 2010, 07:41 PM
Do you know where I might find that info? I did try to take a look but didnt see anything in there.
Old June 14, 2010, 07:59 PM
jcmaz's Avatar
I am going to bet that you dropped the 1055T in with out formatting your windows, causing the windows to "only" recognize 2 cores.
-Plato
Old June 14, 2010, 08:06 PM
I am going say yes. I didnt realize that I needed to reinstall windows...well thats a bummer.
Oversized Rooster's Avatar
There is no need to re-install Windows or "tell" it how many cores you have.
I successfully upgraded one of my cottage machines from a Phenom 940 to a Phenom 1055T last week. I just needed to restart it once.
Windows will detect the new cores and load drivers for them on first boot.
Main: Intel 2600K @ 4.8GHz | Gigabyte P67A-UD7-B3 | 16GB Corsair DDR3-2000 | 2 x 240GB Corsair Force 3 in RAID1 | 2 x 4TB Hitachi 7K4000 | 3 x 2TB WD Caviar Black | 3WARE 9650SE | Antec 1200 | Seasonic XP-860 Platinum | 2GB GTX 670 | 2 x 27" Asus VE278Q | Auzentech Prelude | Win7 Pro 64-bit
Old June 14, 2010, 08:11 PM
supaflyx3's Avatar
That's not always the case though.
I've upgraded CPUs that were similar before, and it would end up with BSOD's or windows locking up.
I'd also suggest reformatting, and making sure there isn't a setting in your BIOS preventing the motherboard to utilize each core.
Old June 14, 2010, 08:13 PM
geokilla's Avatar
Never heard of reinstalling Windows so it'll recognize the new CPUs...
@OP. Have you tried resetting the BIOS to default settings? How bout clearing the CMOS?
1055T or i7 920? (EDIT - went with LGA1156 setup) Fracture New Builds 13 May 23, 2010 06:12 PM
AMD 955 or 1055T? jcmaz CPU's and Motherboards 7 May 17, 2010 07:55 AM
8 Intel cores faster than 16 AMD cores? Babrbarossa Rumor Mill 0 May 24, 2007 06:54 AM
