Old June 13, 2010, 09:52 PM
Default Asus A7PRO display problem
Problem:
-power system on
-CPU fan spins
-No display
-No beeps
Info:
-Ram tested good
-PSU tested good
-CPU tested good
-video card tested good (tried multiple also, one in PCI slot, one in AGP slot)
-Motherboard power light on
-Monitor tested good
-Motherboard set to bios mode.
-also tried manual configuration 100MHz FSB and 10x multiplier
-also tried manual configuration 133MHz FSB and 10.5x multiplier
Equipment:
-Athlon XP 1600+
-Asus A7PRO rev. 1.04
Thanks in advance for your help guys. I've been at this for a while with no solution. If you have any questions or need more information, please ask.
Here's a link to the motherboard manual: http://www.bcom.de/ftp/treiber/Asu [...] ro-102.pdf
Old June 18, 2010, 04:04 PM
Wurmer's Avatar
Just asking, how do you know you ram is good. I am wondering because this happened to me twice and twice the ram was faulty. It might be only one of your sticks that is at fault, have you tested each of them ?
Old July 5, 2010, 06:57 PM
^ Yes. They both came right out of my working pentium III system. I even tried just one or the other just to be sure. I put them back in the PIII system, and they work fine.
Old July 5, 2010, 07:22 PM
sswilson's Avatar
Just so we're clear..... you've tried both an AGP and a PCI vid card and you're still not getting a post?
That link isn't working..... is this one of the early boards that required you to set clock speeds with jumpers? Definitely sounds like the CPU isn't getting through post on the motherboard.... If the cpu posts on another board, maybe the motherboard is toast.....
Hopefully this link to the manual PDF will work....
http://www.bcom.de/ftp/treiber/Asus/.../a7pro-102.pdf
Specs for the proc....
AMD Athlon XP 1600+ - AX1600DMT3C
Looks like it should be 133 / 10.5 / 1.75 Vcore.
Sounds like you found the bus speed and multiplier settings... did you do the manual voltage adjustments as well? (I'm assuming that you've verified that you've also disabled the jumperless settings).
edit: This is bringing me back a long ways!!!! seems to me that's the board I fried my 1G thunderbird on...... ;)
Old July 9, 2010, 08:39 AM
sswilson's Avatar
Did you have any luck with this?
Old July 9, 2010, 01:08 PM
Nope. I've already tried everything you mentioned. And actually, since I posted, I tried booting the CPU in another computer. The computer doesn't officially support the model so it wouldn't do anything past post but it would post and I could get into the bios. Sigh, looks like I'll be looking into another motherboard for it. Know any good electronics junkyards where they actually let you in and take anything you want?
Old July 9, 2010, 01:53 PM
sswilson's Avatar
Socket A/462?
Where are you located? I might have a local source @ $10 for a new motherboard.... if so I can ship it to you if you can do emt to me for the money.....
Old July 9, 2010, 08:08 PM
Socket A/462?
I can't do emt.
Asus O!Play R3 windows 7 sharing problem tedeum HTPC Systems & Software 3 April 16, 2010 08:28 AM
Asus P5Q Pro RAID Problem Rison Troubleshooting 6 September 2, 2009 01:14 PM
Asus 4890 Problem Cowboy Video Cards 2 July 9, 2009 04:29 AM
Secondary USB Display not working with ASUS Video card Brad P Troubleshooting 1 May 23, 2009 06:48 AM
No Boot/display on brand new Asus P5N-MX board the_bandit87 Troubleshooting 17 June 18, 2008 02:55 AM
