Old June 11, 2010, 12:19 PM
CoolHandL's Avatar
Default Double Bios Post Screen at start up?
This may sound stupid, but im trying to figure out why Im getting the post screen twice, once initially at start up A quick screen about the raid controller then another Post screen, whats with the double posting, totally kills my boot time.
I havent tried the quick boot option.
Motherboard Asus P5Q Pro Turbo
Processor Intel Q6600 w/Hyper 212+ cooling
Memory 6GB Kingston
Video Card(s) 2 x Sapphire HD5750 Vapor X Crossfired
Hard Drive(s)
1 x Corsair Reator R60 SSD Boot/Applications Drive
1x 640GB Samsung F1 Hotswapable
2 x 640GB WD Black in raid 0 for fast Storage
Power Supply OCZ ModXtreme Pro 500W
Operating System W7 Ultimate 64Bit
Old June 17, 2010, 03:37 PM
its normal... it doesnt post twice, its just the bios checking for hard drives on the raid controller.
if you arent using it, you can disable the raid controller and it will skip that check. this will mean you only see the post screen once, and it should speed up your boot time too.
Old June 17, 2010, 04:32 PM
The RAID controller has its own BIOS, so what you're seeing is that BIOS performing its POST. If you don't want to see it, then like tehpr0fess0r said, you can disable the RAID controller (assuming you aren't using it for anything), and you won't see the message. If on the other hand you are actually using the RAID controller, then there's nothing you can do.
Old July 3, 2010, 03:14 PM
CoolHandL's Avatar
thanks.
Image corruption on bios load & POST .. Synth Troubleshooting 12 December 24, 2009 12:16 PM
10 Step "No Post" BIOS Recovery Guide sswilson Guides & How-to's 16 September 24, 2009 04:56 PM
wow double post Phobia Off Topic 0 January 29, 2009 12:23 AM
Updating BIOS on GA-EP45-DS3L failed, how to access back up BIOS? Kayen Troubleshooting 5 August 7, 2008 06:31 PM
