Old May 31, 2010, 11:18 PM
mattydies's Avatar
Default Trying to disable speedstep
My work computer is a Dell Inspiron 530. The CPU is an E2160. At first I thought the chip was a super lazy dog (1 meg of cache ). I realized speed step is on, and there is no option to disable it in the bios. I came across RM Clock. Speedstep is still alive and well but the computer seems to have woken up (or perhaps sobred up?). Is there a way to TOTALLY disable or bypass speedstep?
Thanks
Old June 1, 2010, 07:45 AM
JD JD is offline
Probably not, and it really shouldn't make the computer seems slow. It should clock up nearly instantly whenever there's load.
Do you have full OS access? Try changing the power mode to Always On/High Performance.
Old June 1, 2010, 10:52 AM
lowfat's Avatar
Speedstem has almost zero affect on performance FYI. It adjust instantly. There should be no reason for people to turn off Speedstep unless they either run their CPU @ full load 24/7 or they like to waste power.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 1, 2010, 12:44 PM
r0bc's Avatar
With my old Biostar i45 I had to disable CIE Support and Intel C-State along with Speedstep but you won't see a difference .
Old June 1, 2010, 12:54 PM
mattydies's Avatar
I know that speed step is a good thing, save money, energy load, environment...
I know that speed step is suppose to happen in a fraction of a second BUT this computer seems to have a VERY notticable difference between Normal (for the past month) and the past day with RM Clock. I know this should NOT be the case, but it is indeed the case.
Old June 1, 2010, 12:57 PM
mattydies's Avatar
JDRom17 ~ Thanks man. I switched the power mode to "RMClock". the computer is running well over 90% of the time at 1.8ghz now.
Again I know it should not make a difference, but it does. It is noticeable, and not a placebo affect. The computer has more "Horse Power" and better "Throttle Response" =D
Old September 14, 2010, 11:29 AM
mattydies's Avatar
UPDATE ~ During some recent hot weather I decided to detune my PERSONAL computer to stock and enable speedstep. Sure enough speedstep works seemlessly and faster than can be notticed.
I've come to the conclusion the work computer just needs to be formatted and have windows reinstalled (It likely still has the factory installation). Now if work can just find the software for the surveillance cameras I can format and the computer should no longer run like sweaty ass
Thanks again guys
Old September 14, 2010, 11:40 PM
Chilly's Avatar
http://www.hardwarecanucks.com/forum...dstep-f-q.html
There is a nice sticky that explains everything
Speaking of which I should probably update it with new info concerning Turbo, and various software tools to modify and modify speedstep...
Whats up with my CPU? - A SpeedStep F.A.Q. Chilly CPU's and Motherboards 23 March 29, 2012 06:22 PM
Gigabyte p55a USB3 Speedstep Problem AdoP Troubleshooting 4 March 23, 2010 02:12 PM
i7 950 won't speedstep on idle crowTrobot Troubleshooting 1 February 15, 2010 02:34 PM
Q6600 - Speedstep and C1E... Dr_BenD_over CPU's and Motherboards 2 January 17, 2010 08:42 PM
How do I manually disable DirectDraw? mrlie3 O/S's, Drivers & General Software 4 June 4, 2008 07:40 PM
