Old May 29, 2010, 06:06 PM
Exclamation cooler for AM2 6000+
Currently have a retail box AM2 BE2300 and going to install a AM2 6000+. Assume that even with no overclocking I will have to get a new cooler for the 6000+. Any recommendations? Have a Asus M2N motherboard.
Old May 29, 2010, 07:13 PM
try stock and see first. hyper 212+? under 25.
why dont you get a nice regor instead? around 60 bucks
Old May 29, 2010, 07:33 PM
I already have the AM2 6000+ CPU. Would the Regor even work in the AM2? What about Arctic Cooling Freezer 7 Pro Rev.2 CPU Cooler?
Old May 29, 2010, 07:37 PM
jcmaz's Avatar
The AC Freezer 7 is overprice junk. I would get the 212+ like dangX said.
Which M2N motherboard do you have? There are a couple of them...
-Plato
Old May 29, 2010, 07:43 PM
Go with the Hyper 212+
Coolermaster Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA775 LGA1156 120MM - DirectCanada
If not go with the Vendetta 2, it has worked well on my socket 939
OCZ Vendetta 2 Triple Heatpipe CPU Heatsink AM2 LGA775 S939 S940 S754 120MM Fan 800-1500RPM 20-32DBA - DirectCanada
The benefit of the 212+ is that it will fit on all of the current sockets
Hope this helps.
Old May 29, 2010, 07:48 PM
THe base M2N one
Old May 29, 2010, 08:00 PM
it should be ok. the 212+ can be used in the future if you go am3 or something
Old May 31, 2010, 08:27 AM
Phoned the local place here and they are out of stock on the Hyper 212+. The Zalman CNPS19X Performa is $38 but reviews indicate its fan is too loud at full speed. Remember not going to be overclocking.
Old May 31, 2010, 11:52 AM
Bond007's Avatar
OCZ Vendetta 2 is a good cooler. Its doesn't cool quite as much as the 212+, but its more quiet (slower fan on the vendetta 2). I have been contemplating this cooler for a while, since I like cool, but I also like quiet (and a low price).
Old June 19, 2010, 08:55 AM
Wurmer's Avatar
The Vendetta is a pretty decent cooler. Also make sure that you motherboard can accommodate your 6000. I am not familiar with your specific model but some basic MB are limited as what they can take as far as wattage is concerned. For example, I have a AM2+ MB that cannot take a CPU drawing more than 90 watts.
AM2 Air cooler Mir Air Cooling 7 February 28, 2010 06:59 PM
[WTB] CPU Cooler for an AM2 Processor norfolk Buy/Sell & Trade 4 June 29, 2009 10:08 AM
[WTB] CPU cooler for socket AM2+/AM2 yamawho Buy/Sell & Trade 2 February 22, 2009 07:51 AM
am2 x2 6000 3.1ghz 65nm? upcoast604 CPU's and Motherboards 8 January 12, 2009 02:28 PM
AMD AM2 6000+ vs. 4000+ - A benchmark comparison CMetaphor CPU's and Motherboards 14 March 25, 2008 03:47 PM
