Old May 29, 2010, 04:24 AM
Default maximus extreme and cpu
maximus extreme motherboard,what would be a good cpu to work with this motherboard for best performance
will be used for everything ,folding mainly,everyday use and so on
Old May 29, 2010, 05:11 AM
gingerbee's Avatar
one that fits. this is a little vague
Old May 29, 2010, 05:14 AM
i gess u are ,
Old May 29, 2010, 10:33 AM
Budget? Proper English?
Old May 29, 2010, 04:57 PM
FreeKnight's Avatar
You probably need to post a little more (and coherent information) before you're going to get a reply. Maybe let us know -
- Which Maximvs Extreme? The original (X38 IIRC), or (presumably) the current Maximvs III Extreme using the LGA 1156 chip.
- How much money are you willing to put into the CPU? Are you overclocking the CPU or using stock speeds?
Here's NE's list of 1156 processors, maybe this will get you started:
Newegg.ca - Computer Hardware,CPUs / Processors,Processors - Desktops,Intel,LGA 1156
Old May 29, 2010, 05:07 PM
gingerbee's Avatar
Originally Posted by jewellzy View Post
i gess u are ,
of course i am what else is someone to say to such a vague question. good luck
ASUS Launches the Rampage III Extreme and Maximus III Extreme Motherboards FiXT Press Releases & Tech News 4 April 16, 2010 05:40 AM
Maximus III extreme? BobbyLou CPU's and Motherboards 8 April 7, 2010 08:51 PM
Maximus 3 Extreme gambel626 CPU's and Motherboards 17 February 25, 2010 02:39 PM
ASUS Maximus Extreme confusion CPU's and Motherboards 6 December 23, 2008 04:42 PM
Maximus Extreme SagManQc CPU's and Motherboards 35 December 21, 2007 08:15 PM
