I'm sorry I totally forgot about your post. Re-reading the whole thing, I think you are still mislead regarding the naming convention of the Ram speeds.
200MHz = PC3200 = DDR400 --> not DDR400MHz.
Since you oc'ed your CPU to 217MHz, and are using a Ram multi of 3:5, everything adds up.
217MHz x 3/5 = 130MHz. But since the Ram is running at Double Data Rate (DDR), the actual speed is 260MHz.
Hope this help.
John
__________________ The Four Horsemen. S8812 - 6174s - Ripjaws 16x2Gb - X25M - A5s - AX750W - 932ADV Game on. X58A-OC - 930 - 560s - OCZ 3x 2Gb - Vertex 3 Max IOPS - TRUE Cu - AX750W - LC13 - U2412M.
