-   -   Core Temp Accuracy =/ (http://www.hardwarecanucks.com/forum/cpus-motherboards/3255-core-temp-accuracy.html)
Yamcha November 14, 2007 03:22 AM
Hi guys, this has been an ongoing issue for me, still I'm having a hard time believing the temperatures that Coretemp show are accurate. As you can see I got great airflow, a really good performing HSF aswell.
CoreTemp Load (Dual Prime) 60C
SpeedFan (Dual Prime) 45C
Tjunction: 100C (According to Coretemp)
Shouldn't my temperatures be lower?? I've seen other people who are running the same processor higher volt, and higher fsb but lower temperatures using similar cooling, I think Coretemp shows incorrect Tjunction for mines. I've even touched the HSF its a little warm to touch, hardly feels like 60C, remember I've got an Antec Nine Hundred = 200MM, 3X120MM Fans, wires are tidy not getting in the way of airflow, how is it possible that I have such a high load temperature??
My Specs
GIGABYTE P35-DS3R
INTEL CORE 2 DUO E2160 @ 333X9 1.325V
THERMALRIGHT ULTIMA 90 W/90MM FAN
2X1GB CRUCIAL RENDITION PC5300 5-5-5-14
EVGA 7600GT 256MB DDR
WESTERN DIGITAL 500GB SATA3.0 7200RPM
SAMSUNG SH-S203B SATA
ANTEC 430 EARTHWATTS
ANTEC NINE HUNDRED ATX CASE
Feedback is appreciated
Screenshot
http://img230.imageshack.us/img230/1359/screenykb6.gif
enaberif November 14, 2007 03:50 AM
Uh how is coretemp not right? Thats 36 idle and 60 under load.. very normal.
Yamcha November 14, 2007 04:10 AM
What Temp's are you getting on Load?
BALISTX November 14, 2007 04:20 AM
Here is what I get up with my setup.
Setup:
MB: Gigabyte GA-P35-DS3L (Rev.1)
CPU: Intel Pentium Dual Core E2180 @ 2.75GHz (M0 Stepping)
CPU Cooling: Stock Intel HSF
RAM: Mushkin HP-6400 PC2-6400 DDR2-800MHz @ 825MHz 4-4-4-12 2T
GPU: XFX GeForce 7900 GS Extreme Edition GDDR3 256MB 256-bit (G71 GS) @ Core - 480MHz / Memory - 1400MHz
NB Cooling: Stock
SB Cooling: Stock
PSU: Corsair VX550W 550 Watt
HD: Seagate 250GB 7200rpm 16MB SATAII
OS: Windows XP Pro SP2
Ambient Temperature: 19-20C
Case Fans 1x120mm Exhaust and 1x80mm side intake.
CPU Temperature: Core 0 27C / Core 1 28C @ idle
Core 0 36C / Core 1 40C @ load
Game Play Temp: 54C
http://www.hardwarecanucks.com/image...376d5ef039.jpg
enaberif November 14, 2007 04:36 AM
Under load I'm about 50-55 degrees but cooler and fan makes a huge diff.
Yamcha November 14, 2007 05:35 AM
Yeah thats exactly what I was wondering, my HSF well according to reviews cools almost as well as the tuniq tower, maybe at most 2-3C higher on load then urs.
heres a screenshot
http://images.anandtech.com/reviews/...ma-90/load.png
