Old June 2, 2010, 02:50 PM
JD JD is offline
Pfft $600 only? You should get this single-socket Gigabyte board instead! Newegg.com - GIGABYTE GA-X58A-UD9 LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 XL ATX Intel Motherboard And you can get it right now
Old June 2, 2010, 05:17 PM
steers's Avatar
Well now I have to check this out.
Originally Posted by Newegg.com
Form Factor - XL ATX
Ah, bloody hell EVGA, look what you've done
Old June 2, 2010, 06:45 PM
Liu Kang's Avatar
Originally Posted by martin_metal_88 View Post
Liu Kang, you HAVE to make a workblog about this little baby and tell us which case you will useto fit a ATX-XL mobo in it.
I will post pics when I get it, which FedEx says is June 4th :). It's going into a custom Mountain Mods Ascension, but the build log might take a while since the SR-2 doesn't have any water blocks yet.
LK
WORK KANG: Silverstone SG03 | EVGA x58 Micro w/ 920 @ 4.2Ghz | Sapphire 5970 | 12GB Dominator DDR3-2000 | 240GB Revodrive X2 | SilverStone ST650F
MINI KANG: BitFenix Prodigy | Asus P8Z77i Deluxe mITX w/ 2600K @ 4.5Ghz | EVGA GTX 680 2GB | 8GB Vengeance DDR3-1866 | 2x Intel 160GB SSD | Corsair AX650
KANGZILLA: Custom MM Ascension | SR-2 | 2x X5650 | 2x SilverStone ST1000F | 2x Intel 160GB SSD | 15x 120mm rads | Under construction...
Old June 2, 2010, 08:02 PM
martin_metal_88's Avatar
Originally Posted by Keltron 3030 View Post
This isn't XL-ATX, it's HPTX, Which is a completely different form factor. If I'm correct, it measures about 13.5"x15.5", or in that area.
My bad, I mixed it with the X58-UD9:)
can you still post some pic even before getting the block?? please please please!!!
Old June 2, 2010, 08:06 PM
Keltron 3030's Avatar
Is anyone even doing a block(s) for this beast?
FFFFFFFUUUUUUUUUUUU-
Old June 2, 2010, 09:48 PM
Liu Kang's Avatar
Bitspower will be first to market. Vincent hopes to have it ready soon. No word on EK yet though...
LK
Tags
evga , sr-2 , w555
Phemon II X6 Pre-order @ Fry's jcmaz Press Releases & Tech News 21 April 3, 2010 12:21 PM
Pre Order GTX480 ? [BSN] matsta31 Rumor Mill 18 February 23, 2010 05:07 AM
mass effect 2 available on steam for pre-order BrianHanna Gaming 0 January 13, 2010 07:44 PM
Prince of Persia (PC) Pre-Order $29.99 FS & BB Thund3rball Gaming 12 January 8, 2009 07:59 AM
GTA IV Pre Order? GravyLeg Gaming 15 November 3, 2008 12:56 PM
