-   -   Display Port to Dvi adapter Question (http://www.hardwarecanucks.com/forum/cpus-motherboards/32277-display-port-dvi-adapter-question.html)
Arinoth May 19, 2010 11:41 AM
I currently have a couple of HP 48409-001 display port to dvi adapters and were wondering if these were active (will work with eyefinity) or passive. So far i can't find anything on google about that.
Lpfan4ever May 19, 2010 11:47 AM
To my knowledge, for it to be active it would have to be drawing power from somewhere, like a USB port. If it's like a DVI->VGA adapter, I'd guess it'd be passive.
CMetaphor May 19, 2010 11:48 AM
Googling that didn't help much, but anyways... If it has a USB connection on it, it's active. A smaller dongle (like one that looks like a straight cable, no "box") is passive and will not work with Eyefinity.
Arinoth May 19, 2010 12:06 PM
So these things are kinda useless for my desktop if my 5870 has 2 dvi connections and an hdmi connection (i know i cant use more then 2 without the third being an active dp one)
CMetaphor May 19, 2010 12:08 PM
Pretty much... Unless you get and Eyefinity6 card at some point, which only comes with mini-DP to DP i think. Then you could use two of your adapters for the first two DVI outputs and then active ones afterward.
Pankie June 7, 2010 09:40 PM
Do not use an active converter to DP. Usually ends horribly. If you want eyefinity bite the bullet and buy dp monitors, or one atleast.
jcmaz June 7, 2010 09:53 PM
You might find this an interesting read: Mal's Eyefinity Project (Info, Pics, Vids) (Using PASSIVE DP to VGA adapter!) - Overclock.net - Overclocking.net
