Old May 11, 2010, 10:05 PM
Default 4 fans.. 2 3 pin connectors.. what do I do?
I have 4 fans that I want to hook up, but only 2 3 pin connectors on my motherboard.
All 4 fans connect through a 3 pin connector.. any suggestions?
Old May 11, 2010, 10:49 PM
Purchasing a fan controller is one option.
Old May 11, 2010, 10:50 PM
Jake_HT's Avatar
You can buy molex to 3 pin fan adapters. They're a few bucks. Any computer store should have some. A lot of fans actually come with them.
http://jakeht.deviantart.com/
Old May 11, 2010, 11:07 PM
Adapters and fan controllers, alright thanks.
Old May 11, 2010, 11:17 PM
ZZLEE's Avatar
Default 7 $
2 of 3-pin Fan Splitter Cable 3-pin Fan Splitter Cable [3-pin Y-cable] - $2.99 : DazMode, Watercooling enthusiasts store
fan splitter
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old May 12, 2010, 08:28 AM
SugarJ's Avatar
You have to watch plugging splitters into a mobo. They aren't rated to run a lot of power through those fan headers. Check your mobo and fan specs before you do that.
4 Pin PWM Fans connect to molex? chrisk Air Cooling 4 December 16, 2009 10:05 PM
So, were are some of those 3 pin to molex connectors for fans? Z Overlord Air Cooling 10 October 21, 2009 12:13 PM
6-pin PCI Express to single 8-pin no_pulse Power Supplies 12 July 8, 2008 04:46 AM
3 Pin to 4 Pin Fan Plug Adaptor? Thund3rball Video Cards 6 March 25, 2008 01:46 PM
8 pin or 4+4 pin CPU connection ? Unklmo CPU's and Motherboards 4 August 8, 2007 06:05 PM
