Old May 7, 2010, 08:47 PM
Default Overclock Menu on ASUS motherboards
I've spent the last hour searching for this and can't find the answer. I have an ASUS P5VD2-VM SE motherboard, pretty old, never overclocked it before, but have seen that other people have.
I know for gigabyte mobos, it's Ctrl+F1, I was wondering what the magic keys for Asus mobos are.
Thanks in advance!
New on HWC but lots of feedback on RFD (89-0-0)
XBMC Rig (1900PPD): AMD Athlon II X2 240 @ 3.2ghz | Gigabyte GA-MA78LM-S2H | G.Skill 2GB DDR2 800 | WD Caviar Blue 500GB | Antec NSK1300 SFF Case
Folding Rig: (1700+4500PPD) Intel Core 2 Duo E6600 | Gigabyte GA-P35-DS3L | OCZ Special Ops 2GB DDR2 800 | EVGA 9800GT | G.Skill Falcon 64GB SSD | Samsung Spinpoint 1TB | Seagate Momentus 1TB | Generic ATX 430W Case
Old May 7, 2010, 08:48 PM
Check Asus forum.
"What is the colour when black is burnt ?" - Neil Young
Old May 7, 2010, 08:58 PM
Originally Posted by crazyhorsejohnny View Post
Check Asus forum.
I found exactly these responses when I tried searching
People in forums would say 'check asus forum'
and people in asus forums would say 'check other threads'
I just can't find those threads, so if someone actually knows, I'd really appreciate it.
Old May 7, 2010, 09:57 PM
The newer boards have the AI Tweaker right up top with the other main menus. The P5K-E I have, you have to go to Advanced -> Jumperfree Settings. That's where most of the good stuff is, might be the same for your board.
Do you have the manual, or if not the paper one, have you downloaded it? Asus gives a decent listing of the various settings. Just look for the ones that apply to overclocking, like cpu frequency, dram frequency and timings, as well as your various voltages.
Old May 7, 2010, 10:31 PM
howpet's Avatar
Reboot + delete before it posts, everything should be rite there.
Old May 7, 2010, 10:45 PM
ASUS BIOSes do not have hidden menus. Everything is right there when you go in. If you need help finding the overclocking settings, download the manual for your motherboard off of ASUS' website and read through that.
Old May 8, 2010, 06:00 AM
I guess my mobo doesn't have it then. I've looked through every single menu in my bios. No mention of overclocking in the manual, I didn't think the mobo could do it until other people said it could.
I've also updated the bios, but the bios is very basic...
Old May 8, 2010, 08:21 AM
It may be because of the VIA chipset (if I read your mobo's manual properly)... VIA's been all about low-power embedded systems and underperforming HTPCs, so even if you could OC it I doubt you'd get very far.
Can you do an overclock through software? See if Asus has the "AI" software available for your board. I can't recommend some of the other software OC options because they've led my system to instability each time I tried.
Old May 8, 2010, 08:30 AM
Agreed. No hidden areas in my ASUS bios. It not blatantly labeled as overclocking, but the setting are all there (frequency, memory speed and timings, etc).
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
The Latest Generation of Motherboards Shown in the ASUS P6X58D Premium Soultribunal Press Releases & Tech News 10 January 22, 2010 04:37 AM
ASUS Introduces P7P55D Series Hybrid Motherboards FiXT Press Releases & Tech News 0 September 10, 2009 10:21 AM
Asus Annouces "Absolute Pitch" Series Motherboards for Audiophiles FiXT Press Releases & Tech News 10 August 27, 2009 10:09 PM
ASUS Unveils M3A78 Series Motherboards MAC Press Releases & Tech News 13 June 10, 2008 01:52 PM
ASUS official partner for 4x4 motherboards UNESCO CPU's and Motherboards 3 November 23, 2006 10:53 PM
