If you're below 100C, you've got nothing to worry about. You've got plenty of headroom. One important thing to keep in mind is that it's impossible to get your CPU hot enough to damage it, because it has thermal protection features that will prevent that from happening. As long as you stay below 100C, they will not take effect, so you can run your CPU at full load below that temperature without having to worry about any performance effects.
Originally Posted by enzo matrix The temperatures are normal for load temperatures. You don't want the temperature to get any hotter than that though. 72C is the thermal limit of the i7 on the 1156 platform.
Although I am surprised you are getting warm temperatures like that with an aftermarket cooler... then again, I have no experience with the core i7 myself. |
The thermal spec (not thermal limit) is completely meaningless and has absolutely nothing to do with maximum safe temperatures for Intel CPUs.
