Hey, I got a problem with my S4985.
It shows 45, 87, 28, 2A, then 2C, and then it shuts off.
I have 4x CPUs 8356's on it, and i'm using a 1600w PSU.
When I tried it with 1x CPU, it worked!
But with 4x, no luck.
There is only 1, 8 pin on my PSU, so I had to buy a cable that converts 4 pin into a 8 pin.
I just ordered 6 pin pci-e to 8 pin 12v converter, so hopefully this works, or i'm getting a new PSU.
My problem is discussed extensively in this thread here:
AMDZone.com • View topic - Ran my S4985 for the first time. Didn't work.
If anyone tell me what those numbers mean, I would appreciate it.
