-   -   MSI K9A2 Platinum compatible CPUs? (http://www.hardwarecanucks.com/forum/cpus-motherboards/31390-msi-k9a2-platinum-compatible-cpus.html)
Kalskid April 25, 2010 05:04 PM
Hey there!
I am looking to upgrade my CPU, and I am not sure what will fit into my motherboard. The motherboard I have is this: Newegg.ca - MSI K9A2 Platinum AM2+/AM2 AMD 790FX ATX AMD Motherboard . I am looking to upgrade the CPU to a 3.0 gHz quad core, but when I was looking at some of them, most of them needed a AM3 socket, while mine is only AM2 and AM2+.
I found this CPU, which looks like it will fit, but I would like clarification before I order it :p Newegg.ca - AMD Phenom II X4 940 Black Edition Deneb 3.0GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM2+ 125W Quad-Core Processor - Processors - Desktops . The socket types match, but the only thing that concerns me is the lack of a cooling unit under specifications. Can anyone recommend one that would fit with my mobo?
Thanks,
a helpless noob :ph34r:
sswilson April 25, 2010 07:05 PM
Any AM3 up to (but not including) the new hexa-core chips will run fine on it. just make sure to update the bios first. I'm currently running a 955be on mine with no problems.
Alouette Radeon December 3, 2010 10:43 AM
All Phenom II X6 CPUs are now supported by the K9A2 Platinum via BIOS Update from MSI. (Worked fine on mine) :bananafunky:
