Old April 22, 2010, 10:29 AM
Default x4 965BE temperature?
What I did was swap out the 940BE(kid has it now) for a 965BE all the parts are listed in my sig below. With prime 95 load temps shoot up to 53c (room temp 20c max, maybe cooler), cpu set to 18x200 1.4v, is 53c temp normal for tuniq 120? Idle is no problem depending on time of day 27c morning 31c later afternoon.
Thanks.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old April 22, 2010, 11:18 AM
I'd be happy with those temps. Load could be better but the idle temps look much lower then usual. Now overclock some more!
Old April 23, 2010, 07:18 AM
I tried 19x200 @1.4v but it didn't last 10min in prime, got the bsod. I'm going to let the as5 set for a couple of weeks to see if load temp comes down then bump volts up a bit more.
temperature bug phantom_jo Troubleshooting 3 August 3, 2009 03:31 PM
Temperature Too Low? curtispan CPU's and Motherboards 4 January 12, 2009 10:58 PM
Temperature problems =/ Dar_ell Air Cooling 3 December 29, 2008 08:32 PM
I need help with my e8400 temperature pSop CPU's and Motherboards 11 December 17, 2008 08:14 PM
Max temperature Vinnie Overclocking, Tweaking and Benchmarking 4 November 28, 2007 09:08 PM
