Originally Posted by Rapid-X went to clean my computer today went to take out the cpu and give it sum canned air when the cpu itself was forged to the stock fan, i havent even tried overclocking it yet. i got that a part after sum careful pring, but heres the worse part it bent 2 of my pins on the cpu . i tried staringting them but failed on one that was bent completely i reinserted it , systems up and running how can i find out if its causing any problems?? any program out there that can tell me what that pin was controlling?? |
No...there's no "
program" to tell you which pins do what. The best you could hope for is a pin-out diagram. If i were you, i would check clock-speed and vCore in CPU-Z.. just to make sure that it didn't change the voltage. In all likelyhood, you should be fine, as many pins are ground pins, and won't affect anything negatively. The fact that it
is running fine is a good sign.. so i wouldn't lose any sleep over it. I have broken pins off accidentally before, with no effect. GL
