Old April 19, 2010, 04:57 PM
Default ASUS M4N86T-M
Hey guys, a friend of mine wants to purchase the ASUS M4N86T-M but is not sure because the OCZ site said it wasn't compatible. The ram he wants to purchase as well to go with this motherboard i OCZ Gold 4gb (2 x 2gb) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit (Newegg.com - OCZ Gold 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model OCZ3G16004GK). Can anyone explain to me why it's not compatible because I don't see a problem with it. Oh, we would like to know if it's compatible.
Thank you in advance.
Old May 3, 2010, 09:44 AM
I googled that motherboard but this thread is literally the only result. You might want to double check the model.
Anyway, I have an Asus M4N785-M and I am currently using both mushkin silverline and OCZ SLI (each 2x1GB chips) and have no problems. Neither is on the support list (other OCZ models are though but no mushkin)
Compatibility just means that it's been tested. I have never heard of anyone running into problems with "incompatible" ram that is actually incompatible.
Old May 3, 2010, 09:58 AM
Soultribunal's Avatar
I would personally steer clear of the OCZ kits if possible. They really don't put the effort into it like other makers do.
For that go G.Skill, Mushkin, Corsair if you can.
I have had problems with OCZ ram, and trust me there are issues with incompatibility. I've got one DDR2 kit from OCZ that I finally found a board it would work on properly.
So it does happen. As for the list you have for the board (QVL), there are literally too many kits available out there to make it complete. So the board makers tend to get a bit of a baseline from all manufacturers and that forms the foundation, but in no way is it set in stone.
I've had kits that were never part of that list running perfectly on my systems.
ST
www.realhardwarereviews.com
Old May 6, 2010, 06:31 PM
Wurmer's Avatar
Honestly of late, If i don't want to have any problem with my memory I buy good ole Kingston. They are more conservative in many aspects but they are compatible with most every brand of MB. I have yet to encounter any issue with any of their memory kits.
Old May 6, 2010, 07:35 PM
jcmaz's Avatar
I like my Corsair kit even tho the 770T gives it more voltage than needed.
-Plato
Asus Rampage II GENE vs Asus P6T Deluxe V2 Rocco_360 CPU's and Motherboards 3 February 26, 2010 01:04 PM
Installing SSD & W7 (Using Asus Recovery Disc) On Asus G51J Notebooks rjbarker Mobile Computing 0 February 19, 2010 12:36 PM
ASUS Rampage Extreme or ASUS Maximus II Formula AmuseMe CPU's and Motherboards 3 July 20, 2009 09:46 AM
Asus Rampage II GENE vs Asus P6T Deluxe V2..which one? Rocco_360 New Builds 3 April 4, 2009 08:29 PM
[FS] Asus EAH HD4850 and Asus Xonar DX Cypher^64 Buy/Sell & Trade 12 February 25, 2009 10:14 AM
