Old April 8, 2010, 06:11 PM
the temperatures you're getting do seen to be a little hotter then usual, but not overly so. you could be using too much or too little paste indeed (or even paste that isn't very good).. but you also have to let the paste settle a little. The temps aren't anywhere near dangerous though, maybe just leave it for the time being.
Old April 8, 2010, 08:20 PM
jcmaz's Avatar
The CPU could run hotter due to dust build up. Also you should use the same temperature displaying program because I'm running Core Temp and HW Monitor and they display different temps.
Core Temp: 55*
HW Monitor: 66*
-Plato
Old April 9, 2010, 06:28 PM
What about the ambient temp, was it the same. the posotion of the laptop could impact the temps as well.
Old April 9, 2010, 08:13 PM
ambient temp is about the same, same room. I'm going to pull it out and reapply thermal paste again and see if it does anything.
New on HWC but lots of feedback on RFD (89-0-0)
XBMC Rig (1900PPD): AMD Athlon II X2 240 @ 3.2ghz | Gigabyte GA-MA78LM-S2H | G.Skill 2GB DDR2 800 | WD Caviar Blue 500GB | Antec NSK1300 SFF Case
Folding Rig: (1700+4500PPD) Intel Core 2 Duo E6600 | Gigabyte GA-P35-DS3L | OCZ Special Ops 2GB DDR2 800 | EVGA 9800GT | G.Skill Falcon 64GB SSD | Samsung Spinpoint 1TB | Seagate Momentus 1TB | Generic ATX 430W Case
Old April 9, 2010, 09:47 PM
sswilson's Avatar
On a laptop, the most likely culprit would be clogged air vents rather than the actual hsf....
Old April 10, 2010, 08:24 AM
Great suggestion. I took out the HSF this morning, gave all the vents a good blow and quite a bit of dust came out. Reapplied thermal paste and reseated. Sitting at 38 idle now :)
Thanks for all the help guys, would have just assumed it was the cpu getting hotter over time, now I know!
Old April 30, 2010, 12:29 PM
Never use a paper towel on your heatsink. It leaves paper fibres on the surface, which can totally fubar your thermal conductivity.
Old April 30, 2010, 01:55 PM
Paper towels do not deposit fibres unless they tear.
  #19 (permalink)
Old April 30, 2010, 02:20 PM
I'm no expert but it would be safe to say that over time a cpu certainly wouldn't run cooler. Lots of factors though.
"What is the colour when black is burnt ?" - Neil Young
  #20 (permalink)
Old May 1, 2010, 02:12 PM
Hey RLP06,
Do you remove your heatsink frequently after applying some compound? What kind of paste do you use? Do you use too little? too much? Do you try placing the heatsink on top of the CPU before attaching and move the heatsink around in half circles?
I believe over time that the cooling is not as fluid within a system. If you never open your case to clean inside, you risk of your fans developing dust/dirt. This slows down fans overtime and can cause problems. Cooling can be influenced many different ways.
Overly high CPU load and inability to run programs smoothly Maplicito Troubleshooting 15 March 26, 2010 11:32 AM
Totally shocked that my MB could run a Phenom II cpu Shadowmeph CPU's and Motherboards 1 October 14, 2009 02:52 PM
how many fans can I run off of motherboard cpu fan plugin Shadowmeph CPU's and Motherboards 3 August 5, 2009 01:17 PM
Hyperthreading Mode (Core i7 920) makes it run hotter appplejack CPU's and Motherboards 4 January 11, 2009 01:44 AM
Does the X3110 run hotter then E8400? Dashock CPU's and Motherboards 36 August 15, 2008 11:14 AM
