Old March 31, 2010, 03:04 PM
abusedsubstance's Avatar
Default Upcoming 6 core cpu with BC2...
So i thought I'd sign up at HWC today after always browsing the site and much to my surprise it said i already did that awhile ago with the same email.
I recently purchased BC2 since I've been playing MW2 on my brothers 360 (Don't really have a beef with no dedicated servers btw) and I'm shocked at how much better it is, I play at 1680x1050 with low shadows and everything on medium with Vsync ON and of course HBAO off, Runs very playable for the most part but i'm pretty sure FRAPS would just make it feel slow...This is the one game since original Crysis I've been wanting to upgrade for and I'm looking forward to getting a 5850 (Nvidia fan though) and Phenom 945 but after seeing the upcoming 6 core CPU from AMD it's got me wondering if it's gonna be faster then 4 cores?
Old March 31, 2010, 03:20 PM
if it can take advantage of all six cores, yes.
Old March 31, 2010, 03:56 PM
I haven't noticed BC2 using more than one core when I've been playing it, so I doubt a 6-core CPU will make a difference outside of perhaps higher clock speeds. You're far more GPU-limited than CPU-limited; a better video card would be a much more useful upgrade if better gaming performance is what you're after.
Old March 31, 2010, 04:55 PM
weird, i get equal load on all 8 threads when playing bfbc2
Old March 31, 2010, 04:57 PM
Let me rephrase that: I haven't noticed BC2 using more than one core's worth of power while playing. The OS will balance the load across all the cores, but the game really isn't that CPU-intensive.
Old March 31, 2010, 05:21 PM
belgolas's Avatar
A GPU upgrade would be better as you already have a powerful enough CPU. Though it wouldn't hurt to upgrade both.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old March 31, 2010, 07:25 PM
Thank you all for the help so far.
Would you say I'd see the biggest boost in going for the best card i can then instead of a 5850 and quad processor?
I care about minimum frames more than max and averages and thought a quad processor would help in BC2 when there's a lot of action going on and stuff blowing up everywhere...
Old March 31, 2010, 07:44 PM
Patramix's Avatar
i just upgraded from a dual core to a quad core, and i noticed a nice difference in load times and overall game performance.
All of life is forged from Hell, Yet from its beauty our legacy began.
My Boinc Stats
Old March 31, 2010, 07:47 PM
I would say that you'd probably see a bigger boost from a better video card, but at the same time, even a 5850 would be more than enough to run BC2 maxed out at your monitor's native resolution. If I were in your position, I'd probably go for a CPU and GPU upgrade.
Old March 31, 2010, 08:17 PM
belgolas's Avatar
Well if you are going for a quad and a 5850 then go for that as you will get a nice upgrade. If it was the option of either a quad or 5850 I would get the 5850 but since you can get both you should be happy with the extra performance. You will be able to run this game max with AA.
Sponsor a child!
Fight poverty.
Qoute by Perineum
Asus Motherboard Smorgasbord for Upcoming AMD Six-Core Processors FiXT Press Releases & Tech News 6 March 26, 2010 01:48 PM
white screen bc2 cmac79 Gaming 2 March 3, 2010 01:37 PM
Upcoming Intel Core Series CPU's Leaked FiXT Press Releases & Tech News 16 February 2, 2010 12:26 PM
CPU core voltage Gellidius Overclocking, Tweaking and Benchmarking 11 May 15, 2009 10:01 AM
LF: Core 2 Duo CPU orij1nal Buy/Sell & Trade 7 August 28, 2008 01:44 PM
